head choice for my ms3 build
Old 07-04-2011, 07:23 PM
kevmac's Avatar
Default head choice for my ms3 build
I'm sure this ones ben floated before but my car is a little different. Got a 67 camaro swap with 99 ls1/m6 and 3.73 rear gears. I've aquired a ms3 and ls6 intake. Currently has same ol 853's on it. Been looking at prc's and ai both. what do ya think?
thanx
Old 07-04-2011, 08:37 PM
garygnu's Avatar
consider the PRC 2.5 5.3 head.you get a bump in compression with good springs.if you go with TSP tell them what cam you have.get push rods and trunnion bearing also.consider some kaltech rod bolts and a ls2 timing chain.
Old 07-04-2011, 08:42 PM
Randal McSandal's Avatar
243's if you're in a budget
Old 07-04-2011, 11:36 PM
garygnu's Avatar
stock 243/799s would work if you are on a budget.$400 or less .
Old 07-05-2011, 12:53 PM
Captain Double Post
BOBS99SS's Avatar
it all depends on what you wanna spend man,let us know your budget and we could help ya out better
Old 07-05-2011, 07:25 PM
kevmac's Avatar
I can aford a little bit more than just 243, but not ready for trick flow with the added expense. Just looking to see some proven combos
Old 07-05-2011, 08:12 PM
Darkman's Avatar
You may want to look at the Trick Flow 220s as cast - they flow almost as well as the Trick Flow 215s for roughly $700 less and can be reworked later for even more flow.
Old 07-05-2011, 11:58 PM
garygnu's Avatar
look in the dyno section for combo numbers.243/799 with a good valve job and springs can make close to 450 rwhp with a well though out combo.consider a fast 90/92 combo with a cam from Pred-Z or Pat-G.you will need a good tuner.
Old 07-06-2011, 09:26 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I'd say for a very tight budget the stock 243/799 as stated above. But for a little more money, the PRC Stage 2.5 5.3L heads will work very well with that camshaft and be setup to clear so you do not have to flycut your pistons!
http://www.texas-speed.com/p-1172-pr...ted-heads.aspx
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-06-2011, 09:55 PM
SOMbitch's Avatar
TFS as cast with a matching cam if you can swing a few extra bucks. Get Brian to work them if you want a little more....
Old 07-07-2011, 03:51 PM
kevmac's Avatar
Doesnt the tfs heads require different rockers too?
