Replace opti seal?
Replace opti seal?
From what ie read I should. Makes sense but I can't find any? Is it with a kit or something? I'm on my phone so give me a break but I can't find it. Does anyone know where or a part number preferably from autozone or napa or pep boys or a chain I can go pick up tomorrow ? Also any tips? Been reading on opti installs, already have everything off
Just need to get it back in now
Umm, ignore the above suggestion...
Buy a Fel-Pro timing cover gasket set for LT1. It includes all the seals for the timing cover (crank hub, optispark, waterpump) as well as gaskets for the waterpump and timing cover. Use what you need, as the kit is less than $20...
If you are talking about the internal seal on the optispark cover and cap, best bet is to buy a new cap/rotor if the caps seal is bad, or a whole new AC Delco optispark if the cover seal is bad. Using anything else to seal it is a temporary fix and should be viewed as such, ie, you WILL need to replace the opti at some point in the near future.
im going to hijack for a sec, on the back side of the opti there is the "post" that goes inside the camshaft that has 2 "seals" or bushings on it when i removed the opti those things crumbled and fell off, are those needed? or replaceable? my opti works just fine so i dont want to replace the whole thing if i can avoid it.
