Under hood tape and tyraps
Old 07-08-2011, 11:16 AM
Big Al's Avatar
Default Under hood tape and tyraps
What are you guys using for tape and tyraps? The electrical tape melts and the Ty-Raps get hard. Maybe this is a Tucson thing?
Al 95 Z28
Old 07-08-2011, 11:44 AM
RamAir95TA's Avatar
For what?
Old 07-08-2011, 12:39 PM
defaultexistence's Avatar
Zip-ties and convoluted tubing....
Old 07-08-2011, 03:03 PM
Big Al's Avatar
Well, I need to tie the convoluted tubing so the wires quit coming out for one. And also need to tie all the stuff that is near the headers. And for general repairs.
Another question. What are you guys using to waterproof the connectors? I would assume some kind of high temperature silicon based grease??
Al 95 Z28 going together. If I can figure out where all the f'in hoses go...
Old 07-08-2011, 03:43 PM
Village Troll
SS RRR's Avatar
LS1Tech 20 Year Member
The stock seals on the connectors work fine for keeping moisture out. If they are gone then only thing I can think of is to smear a little gasket sealant on them before connecting them, however that can get messy. Zip ties work fine to keep wires away from exhaust primaries.
Old 07-08-2011, 04:37 PM
ZFreie's Avatar
Perhaps i got shitty zip ties, but they didn't last very long before they melted off. I picked up some wire separators that were thicker plastic and they deformed some from the heat but didn't melt like the zipties.
Old 07-08-2011, 05:16 PM
Village Troll
SS RRR's Avatar
They must be far too close to the exhaust. What exactly are you trying to tie down?
Old 07-08-2011, 05:34 PM
ZFreie's Avatar
I'm not the OP but, I have LTs and was trying to keep the plug wires away from the headers. They were about as far away as they could be and still melted.
I was just tossing that out there, no doubt zip ties can be used but I gave up on them melting lol.
Old 07-08-2011, 06:54 PM
Big Al's Avatar
Found some 3M high temperature electrical tape today. Rated to 211 degrees. I'll try it. Going to try to find real Ty-Raps and see if they are made in China like the others.
Al 95 Z28
Old 07-08-2011, 11:46 PM
camar0corey's Avatar
Any harnesses that are ran by headers or other heat sources I wrap in this HVAC tape. In regards to spark plug wires, they are kind of expensive but invest in the heat sleeve things you can get.
Old 07-09-2011, 12:11 AM
wannaB tuner's Avatar
What is hvac tape and i to would like to know where to find black tape that the factory uses for electrical harnesses
Old 07-09-2011, 12:20 AM
Sumter's Avatar
LS1Tech 10 Year
Can get the heat sleeves in an 8 pack on a certain auction site for around $27
Old 07-09-2011, 06:49 AM
pillarpod's Avatar
Originally Posted by ZFreie
They were about as far away as they could be and still melted.no doubt zip ties can be used but I gave up on them melting.
mine are still on
Old 07-09-2011, 09:37 AM
I guess its for heating and air conditioning systems, its metallic like, my brother jokingly calls it tin foil but the stuff works so I don't care.
Old 07-09-2011, 01:22 PM
leadfoot4's Avatar
If you really have electrical harnesses THAT close to the exhaust, and can't route them any further away, you can buy metal zip ties.....
Old 07-09-2011, 01:34 PM
Village Troll
SS RRR's Avatar
I'm curious to know what harness it is. If it's the cluster on the passenger side it can be routed between primaries 1 and 3 straight down through the motor mount and back. IIRC that harness contains the O2 sensors for that side, the PCM ground and starter wires. That way the cluster has plenty of space from any exhaust primary.
Old 07-09-2011, 01:44 PM
ZFreie's Avatar
Originally Posted by pillarpod
mine are still on
I might be zip tie retarded then lol
Still no burnt wires so I don't care what holds them.
Old 07-09-2011, 10:58 PM
I just ziptied my passenger side harness to the A/C hardlines there to keep them off the header, and I wrapped them in that tape. Eh I might take a picture tomorrow if I'm that motivated.
Old 07-10-2011, 06:31 AM
leadfoot4's Avatar
It's Sunday...take it easy!!
Quick Reply: Under hood tape and tyraps
