What underdrive pulley do I need to go with?
I was told to get a Power Bond, but don't know much else.
It'll be going on a 5.3L engine.
any links would be appreciated, too.
Thanks.
Crap... this is the wrong forum. Please move.
Thanks.
LS1Tech Premium Sponsor
It doesn't really matter what engine you're running, but rather what vehicle the other belt driven accessories are from. Is your powers steering, alternator, AC, etc are all from a 4th gen F-body you will need the 4th gen F-body pulley. If they're from a truck, you run the truck pulley, etc.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes sir, you'll need the truck pulley for alignment reasons. All the 99-11 trucks use the same pulley.
__________________
The 25% is more commonly found on the shelf, is the same price in many instances or even a bit less due to most shops stocking more of them than the 10% and therein getting a better price.
__________________
__________________
If your alternator has problems, then yes you can repulley it to help.
__________________
