ss hood modification
Old Jul 2, 2011 | 03:37 PM
98mysticZ's Avatar
Default ss hood modification
ok got a 408 in my car with a gmpp intake and getting a 4150 throttle body.. any one ever cut the back side of the ss scoop out and made a "ram air" or cold air inlet for a carb style filter? i dont wanna run an elbow.. and i have been looking online not being able to find anything!!!
basically cut out the section outlined in black.. and clean it up with fiber glass.. have it resprayed and then under the hood have a "plate" if u will bolted around or under the throttle body that would have the air filter on it.. and would be a more effective setup for a 4150 throttle body???? any ideas or thoughts?
Old Jul 2, 2011 | 06:17 PM
grunt1152's Avatar
Kinda like the C2/C3 L88 hoods, the breather has a rubber seal that goes around the hood and that where their air comes from. I would look into the rubber from one of those hoods and see if you can find a lid from an older vette or something with that style, then cut your hood to fit the opening on the lid. Best I can help.
Old Jul 2, 2011 | 07:04 PM
98mysticZ's Avatar
yea i have been looking in jegs for info on lower plates but i cant find ****.. i have access to a sheet metal break so i am thinking about making and fabing up my own that will seal up.. and then rebracing the hood with metal then glass it all back in.... still up in the air about this though... good thing its not a real ss hood haha!!!!
Old Jul 2, 2011 | 07:31 PM
bozzhawg's Avatar
I know they have some for LT1's 94-97 Camaros with the SS hood, but I am uncertain if they will fit a 98-02.... I have thought about this myself, but have not taken the steps.....
http://www.streetperformance.com/par...135-21003.html
Bozz
Old Jul 3, 2011 | 12:39 AM
98mysticZ's Avatar
Bozz
ok kinda like that but more along the lines of a round 9in filter with a box made around it to channel air to it.. kinda like the base to a prostock scoop!!
Old Jul 10, 2011 | 07:16 PM
s/c'd cav's Avatar
take a look at these - http://www.summitracing.com/search/?...op%20pan&dds=1
though i think its gonna be a little easier to make one , and hope no one gets pissy about the summit link :/
Old Jul 10, 2011 | 07:18 PM
oChristiano's Avatar
6Litereater makes something like this.
http://6litereaterdesigns.com/store/...roducts_id=214
Old Jul 10, 2011 | 07:26 PM
hitmanws6's Avatar
Go look at Taner Bosnalis 8 second camaro, he has an LT1 hood but he sealed his hood to his 4150 TB.
Old Jul 10, 2011 | 09:35 PM
98mysticZ's Avatar
yes thats kinda what i am talking about BUT i will have a gmpp intake and a 4150 throttle body... NOT stock intake!!!
Old Jul 10, 2011 | 10:51 PM
litle88's Avatar
Did you see the latest Gm high-tech performance issue? They have a nice hood on one of featured rides.
Old Jul 12, 2011 | 07:56 PM
98mysticZ's Avatar
http://www.summitracing.com/parts/AA...6100/?rtype=10
this is kinda what i am talkin about !!!!
Old Jul 13, 2011 | 03:08 AM
s/c'd cav's Avatar
like i mentioned you are gonna have to do some fab work , its not something that is common enough of a mod that i could see a company making a exact item for
i was in the same boat with my 04 gto , and i ended up switching back to the regular style intake manifold
Old Jul 13, 2011 | 03:16 AM
3.8redbird's Avatar
A local guy is running a gen 1 sbc in his 96 camaro with an ss hood. he fabbed his own TB shroud to seal to the hood. Since it was an LT1 i think the hood was already cut to force air where it needed and he doesnt run a filter since it is a race car
Old Jul 19, 2011 | 12:04 AM
ProTreeRacing's Avatar
do it
Old Jul 20, 2011 | 01:15 PM
1lejohn's Avatar
I second that. Make it work I think it would be cool. Nascar run a set up like that. The 1st gen Camaros had a system like it also.
Old Jul 20, 2011 | 04:37 PM
Faught's Avatar
^+1 do it
Old Jul 21, 2011 | 07:53 PM
98mysticZ's Avatar
i am... i just need to get the motor back together...... its taking longer then i thought!!
