LS2 Cam Sensor
LS1Tech Premium Sponsor
Like Transam above showed, it is in the front cover, towards the driver's side of the cover. Why are you replacing the sensor? What symptoms are you experiencing?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
For the past 3 months my GTO has had a problem of shutting off as soon as i turn it on.. it doesnt sputter or anything it just shuts off.. I have to set the alarm on then off then it would start. Now it doesnt start at all it just clicks like if the baterry is dead.. i have changed the battery and nothing.. still clicks like if it was dead.
I would bet against a cam sensor issue there. Do you have a "security" light lit-up on your dash gauges?
__________________
Glad to help
__________________
