Umi lower a-arm issue!!!
well ran into another damn issue with the car was getting it off the jack stands and ready to get it wired up at a shop.
basic run down whole front end is UMI . also have strange coilovers and strange drag brakes
well the bottom part of the lower a- arm is hitting the backside of my strange rotors I tried everything possible what is the damn issue?
i will post a pic first thing in the morning im fed up with this damn car about ready to part it out
dont know im kinda pissed you would think an after market a-arm that you paid a pretty penny for would clear, now i have to grind down my brand new a-arms which now will rust and look all hacked up. who sells a-arms that i dont have to do this? I tired of buying brand new **** that should work then come to find out I have to modify it, last time it was my th400 trans mount that was over an inch off, so i had to pay another shop 70 bucks to cut a part off and re-weld it.
If it makes you feel any better, I had to grind my stock lower A-Arms to clear my wilwood rotors with the new kit. Just comes with the territory I guess.
Its not UMI's fault. Im guessing that the offset of the strange brakes is totally different than stock. Not every manufacturer can make products that will work with every single component combination on the planet.
Since you are grinding the bottom of the ball joint cup it will not effect the integrity of the part in anyway. If it did I wouldn't mention to grind it.
Thank you,
Ryan
You are correct and thank you. The Strange drag brakes are off set and one of the only set ups that won't clear with out some grinding. If I remember correctly you need to grind the factory arms as well with this brake set up.
Thank you,
Ryan
Thank you,
Ryan
Thanks
Clear!
Mark.
