Esiest way to remove pilot bearing?
Old 07-27-2011, 06:47 PM
Johnnystock's Avatar
Default Esiest way to remove pilot bearing?
I was doing the chisel method(after taping the bearing for 2hours and sharpening every screwdrivers I had, it was enough).
I will try this and give feedback, but I hope my chisel mess did not damage anything
http://www.youtube.com/watch?v=1xuR7T8G1Ys
Old 07-27-2011, 07:31 PM
crainholio's Avatar
Do that on an LS engine and you'll displace the crank plug, spewing oil all over your brand new clutch.
Advice fail.
Old 07-27-2011, 07:47 PM
bigj2717's Avatar
Why don't you just rent/buy a blind hole puller and do it the easy way?
Old 07-27-2011, 10:33 PM
Advice fail.
I tried and it didnt work and lucky me, no oil spill. I'll double check the crank plug, thank you!
..So I hammered the **** outta it. 2 hours later its out. I heard the tool is ****, but next I'll try it..cant be worst.. life of a DIYer is tough!
Old 07-27-2011, 10:34 PM
I will edit the title lol
Old 07-28-2011, 03:43 PM
ghettocruiser's Avatar
That method is no where near as clean, quick and easy as using a good blind hole puller.
This set from Autozone is free to rent, and as long as you grab one that isnt all mucked up, works like a dream on even rusty bearings that are falling apart. Use it, clean it up, take it back and get your deposit. I ended up finding a used set on craigslist though because I found many other uses for it. Neat tool to have.
J.
Old 07-28-2011, 07:06 PM
crainholio's Avatar
You may have misunderstood what you heard...the blind puller set from AutoZone is the ****!
Works great, doesn't ding up the crank, and a few whacks w/ the slide hammer is all it takes to remove even stubborn factory pilot bearings.
Old 07-29-2011, 08:20 AM
jarretthise's Avatar
It's a very nice tool for sure.
Quick Reply: Esiest way to remove pilot bearing?
