gatorlover
08-01-2011, 07:39 PM
Hey Guys,
I got a quote from a local shop today for a cam and wanted to see what your opinion was on the specs of the cam. Here is all the work involved.
First let me level set by sharing the current mods on my car.
2010 2ss L99
K&N cold air intake
1 7/8 XSpower long tubes with cat delete connection pipes
Borla "s" type catback 2.5"
Jannetty Tune
As for the quote, this is what it includes:
3 bolt cam 225/230 .617 / .612 112 LSA
Remove and
Replace Camshaft, Requires
DOD/VVT Delete Lit and
Installation-Remove and Replace
Lifters,Valley Cover, Head Gaskets
Naturally Aspirated Electronic Fuel
Injection Tuning
GM VVT Delete kit-Engine Front
Cover Gasket
DOD Delete Kit-LS7 Lifters,
Valley Cover, Lifter Trays, Head Bolts
Camshaft, Pushrods, Double Valve
Springs, Valve Seats, Valve Seals,
Water Pump Gaskets, Timing Cover
Gasket, Front Cover Seal, ARP
Crank Bolt
GM MLS Cylinder Head Gasket
8 Quarts Oil, Oil Filter, Coolant
Curious if anyone else has a cam like this and what are your thoughts on how it will behave as a daily driver.
2010 2ss L99
K&N cold air intake
Jannetty Tune
Remove and
Injection Tuning
Cover Gasket
Crank Bolt
