oil pressure sending unit
I have the long(tall) 1 wire oil pressure sending unit for the F-body now. I'm swapping a LS3 block in and it has the pedestal on the valley cover for the pressure sending unit. This leads me to believe I need the shorter one. The only shorter I have found have 3 wires. Does anyone know the correct number oil pressure sending unit part number I need?
Thanks
Ed
Thanks
Ed
You can use the long sensor. I have an lsx block with the same valley cover and I used the long one. My fast 102 intake sits higher than the sender with the pigtail attached.
I tried to go to O'Reileys to get a 90* fitting and the guy was an idiot. I swear all they ask those counter people if they know what an oil filter is and if they can use a computer!
