Let me see where you relocated your cruise control box to...
So the one thing that I need to address right now is relocating my cruise control box because it's keeping me from rotating up my air inlet tube a little higher than it is right now. I don't have any brackets from the kit, so I need to fabricate something myself, but I'm not sure where to move it to.
Only issue I may have is right now I have my bypass valve on the driver's side under the fuse box location.
Thanks guys.
Thanks guys.
I didn't have cruise but wanted it on my camaro. I installed a one from an s10, it doesn't have that extra traction control crap. I installed the box along the frame next to the starter.
It was awesome to have last year on the hot rod power tour.
check out my build thread, I put mine where your BOV is but you could put yours on the inside of the frame rail.
https://ls1tech.com/forums/forced-in...framerail.html
