LS6 EGR adapter?
Edit, just did some searching and according to a thread I found SLP discontinued them, but people have drilled a hole in the intake to make it work.
https://ls1tech.com/forums/generatio...questions.html
Only other thing I know is to get the SLP LS6 intake that is made for LS1 cars that have a EGR provision. But those are not attachments they are incorporated into the whole intake
http://www.speedinc.com/catagory.cfm?catagory=Induction
Passing emissions is always a good thing.
Plus, I've read that there's the potential to lose a few mpg after losing the EGR. Anyone know if this is true? This fact alone is what makes me want to keep the EGR if I were to ever do an intake swap.
You'd more than likely see a mileage increase; the EGR system simply recirculates spent exhaust gases into the incoming fresh air charge to reduce combustion chamber temps (thus lowering nitrous oxide emissions), so with no EGR system on the car, the engine is actually more efficient.
well, since june when i installed the manifold. the mod itself was fairly cheap. i think i paid $11 bucks for the fitting and another $8 for the jb weld so i guess it totaled around $20, not including the paint for the intake.
