93 lt1 into a 95
Old 08-14-2011, 07:41 PM
THE1320's Avatar
Default 93 lt1 into a 95
Ok guys I'm kinda of new to the lt1 stuff. Any help would be appreciated. I picked up a 93 z28 m6 a while back with the plans of building a track car with a lsx and th400. I just recently picked up a 95 trans am roller for parts it had and to swap the 93 over to it. Looking over both cars it looks pretty straight forward. Looks as if I can pull the engine harness from the kick panel and install the 93 wiring. All the plugs are the same with exception of the 93 having a few less wires. Am I overlooking anything? Or do I need to repin or add any other wiring?
Old 08-14-2011, 07:44 PM
defaultexistence's Avatar
Why not use the 95's wiring to run the motor...??? Why switch to the 93 ECM ? When the motor will just plug and play...
Old 08-14-2011, 07:49 PM
THE1320's Avatar
I'm missing the 95 pcm and mar along with some other things. Basicly just have the 95 harness. And I have a complete donor. Seems easier and cheaper than sourcing the parts. I'm missing.
Old 08-14-2011, 07:53 PM
3.8blackmaro's Avatar
We put a 93 TA Lt1 into a 95 v6 Camaro body. Should just be plug and play. The only issue we ran into is that we had to put a switch in the fuel pump relay circuit because for some reason it didn't want to send power to the relay.
Old 08-14-2011, 07:57 PM
THE1320's Avatar
Maybe that's what the extra wiring in the 95. Relay may get the signal from the pcm.
Old 08-14-2011, 08:00 PM
shix's Avatar
you will have to repin a few connectors. Its not difficult. Here is a link from shoebox's site. http://shbox.com/1/harness_connector_faces.htm
There are tabs at the bottom of the screen for the different connectors. His site is very helpful.
Old 08-14-2011, 08:09 PM
THE1320's Avatar
Thanks shix I will check that out.
Old 08-14-2011, 08:32 PM
Wish I would've seen that when I did it.
Old 08-14-2011, 09:35 PM
shix's Avatar
yeah im finishing swapping my 94 lt1 into a 96 v6 car. That website is like a bible to me haha
Old 08-15-2011, 05:48 PM
I have a 95 PCM for sale if it'll helps...
Old 08-15-2011, 06:11 PM
shix's Avatar
93 runs on map sensor 95 runs map and maf. would be more work for him to run a 95 pcm
Old 08-15-2011, 06:27 PM
Did u miss the part where he's putting a 93 motor in a 95 roller? He says he Lacks a PCM and a maf, well then.. I have a 95 pcm available. And swapping the 93's wiring over would be more work and less tunable.
Old 08-15-2011, 06:34 PM
shix's Avatar
he would still need maf. he already has a 93 pcm so why not just repin the 3 connectors and use it. He is looking for cheap as well.
Old 08-15-2011, 11:14 PM
THE1320's Avatar
I'm not looking to spend any more money than I have to right now. Just looking to use what I have already. Thanks anyway.
Quick Reply: 93 lt1 into a 95
