Anyone here boosting on Prc STG2.5 5.3L ?
Old 08-17-2011, 06:15 PM
1stIDFO's Avatar
Default Anyone here boosting on Prc STG2.5 5.3L ?
I have an 02 SS with a stock bottom that im currently dd. Soon i'll no longer need to dd it and was hoping to take it off the road and start looking for a shortblock to boost on this winter. I'm trying to work the total cost out, so im curious if i can re-use my prc heads and use dished pistons to help lower my comp. ratio....So any one boosting on em?
Old 08-18-2011, 08:58 AM
1stIDFO's Avatar
No one? at all?
Old 08-18-2011, 09:04 AM
Loudmouth LS1's Avatar
Should be as good as any other stock casting head. Since you already have them, I would reuse them and you could always upgrade to an aftermarket casting/thick deck head later on. Obviously it will lower your compression some with the bigger chamber, so maybe run a piston that nets you a little higher now so it drops to where you want later. BTw, what is the chamber size on those heads, because I know my stg 3 tea 5.3's were a 64cc head after the work they did on them which puts it right around the same as most of the aftermarket casting heads.
Old 08-21-2011, 04:36 PM
1stIDFO's Avatar
Im not sure about the exact chamber size now i can find out after theyre off...However i was told im over 11:1 comp....which is why i was wondering if i could gain cc's somewhere in the bottom i have to replace any way lol
Old 08-21-2011, 07:31 PM
NitrOmm's Avatar
I am in no way an expert on the texhnical side of yhis question however, I am running these heads in my DD ls2. I was instructed to run a cam with a larger intake duration which would help with the higher compresion. I have a roots type blower and used comp blower cam 239/243 .624 lift 114 lsa. It's a little rough as drivabilty goes but is making great power. Mine was at 10.2 compression. Keep in mind roots blowers respond better to a little higher compresion.
Old 12-15-2011, 03:24 AM
dtsti's Avatar
Bump for more info. I was going to ask this same exact question. Glad I searched. Would I be able to just use a thicker head gasket? Also which HG would be best and where do I get it from?
Old 12-15-2011, 05:29 AM
blue00ZZleeper's Avatar
Are you using them on a stock bottom end?
Old 12-15-2011, 03:20 PM
dtsti's Avatar
My car is on stock bottom end yes.
Old 12-15-2011, 09:19 PM
That's going to leave your compression on the high side. What fuel are you using and how much boost are looking to run?
Old 12-15-2011, 11:28 PM
dtsti's Avatar
What about on an ls1 block? I also have one sitting around. I plan on using e85 but it would be nice to be able to use pump gas also.
I have a set of 317 heads laying around but my prc heads are ported and have all the upgrades that a boost head would need.
Old 12-16-2011, 03:16 PM
93camaro_zzz's Avatar
When I dynoed the numbers in my sig, that was with a 370", Patriot Stg II 5.3 heads shaved to about 56-58cc chambers on 236/232, 114LSA cam.
Old 12-16-2011, 04:06 PM
dtsti's Avatar
Is there anyway to check what the compression is while the motor us still in the car?
Old 12-16-2011, 09:33 PM
Add all your numbers up in a compression calculator. With and decked heads and a stock bottom end your compression is going to be higher then 10.1:1. With E-85 you should be ok if your not trying to run too much boost.
Old 12-17-2011, 12:51 PM
dtsti's Avatar
Am I able to just put a thicker head gasket on? I wasnt sure if my motor has arp head studs so I could replace the gasket then.
Old 01-01-2012, 10:45 PM
dtsti's Avatar
Bump to answer this question.
Quick Reply: Anyone here boosting on Prc STG2.5 5.3L ?
