Anyone here boosting on Prc STG2.5 5.3L ?
I have an 02 SS with a stock bottom that im currently dd. Soon i'll no longer need to dd it and was hoping to take it off the road and start looking for a shortblock to boost on this winter. I'm trying to work the total cost out, so im curious if i can re-use my prc heads and use dished pistons to help lower my comp. ratio....So any one boosting on em?
Should be as good as any other stock casting head. Since you already have them, I would reuse them and you could always upgrade to an aftermarket casting/thick deck head later on. Obviously it will lower your compression some with the bigger chamber, so maybe run a piston that nets you a little higher now so it drops to where you want later. BTw, what is the chamber size on those heads, because I know my stg 3 tea 5.3's were a 64cc head after the work they did on them which puts it right around the same as most of the aftermarket casting heads.
I am in no way an expert on the texhnical side of yhis question however, I am running these heads in my DD ls2. I was instructed to run a cam with a larger intake duration which would help with the higher compresion. I have a roots type blower and used comp blower cam 239/243 .624 lift 114 lsa. It's a little rough as drivabilty goes but is making great power. Mine was at 10.2 compression. Keep in mind roots blowers respond better to a little higher compresion.
Bump for more info. I was going to ask this same exact question. Glad I searched. Would I be able to just use a thicker head gasket? Also which HG would be best and where do I get it from?
I have a set of 317 heads laying around but my prc heads are ported and have all the upgrades that a boost head would need.
