stall
stall
is this a good stall
what the diffrence in the mm dose it have anything to do with performance im going to run a mild cam 225/230 .580 112lsa
any info on this cam????
http://www.circledspecialties.com/p-...converter.aspx
Save up and get the Pro Performance series. Chris at Circle D is a great guy, you can use the "Ask Chris" link on the Circle D site to talk to him about it.
I have that converter. It's a great converter, but honestly I wish I would've gone bigger. If you are looking for an almost stock feel to a converter, this is it. If you're wanting something that yanks the tires and puts you right into the meat of the car's power, get a 3600 or 4000. My car's a DD, so that converter does great for what I do with it.
Scott
Scott
^This. Wish I would've done it the first time around! Thought I knew enough about what I wanted to ignore everyone's advice of "go higher or you'll be wanting more later." Take it from someone who thought he knew better and found out later he didn't. Go higher. Unless, of course, you really don't want a stall anyway except that you need to do it to run a cam.
Scott
Scott
