Source for Water Pump Seal tool?
I'm not about to spend 80 bucks on a piece of plastic... that's ridiculous. I know someone made the tool out of aluminum and was selling them for about 15 a few years ago, but he has since stopped making them....
I can't find those big sharpie markers anymore either. Apparently when I used the drive shaft coupler to instal the seal last time it still got screwed up, so does anybody have a source for the proper installation tool? BTW, I'm talking about the water pump drive seal that goes into the timing cover. My new one leaks like a sieve.
I'm talking about the tool that allows you to slide the seal on to the water pump shaft, not to pound it in. I have plenty of sockets for that part, but I'm pretty sure I either tore or folded the seal over when installing it since it still leaks. I used the water pump drive shaft coupler to install it last time.
I think i ended up using a 12 or 13mm socket to do this.
I picked up one of the "tools" for $15. It measures 17.65mm ND A 12MM SOCKET MEASURES 17.60....so that will work
the tool does have a beveled tip which makes starting the WP seal over it easier than a socket
they both work
they both work
I'll try a socket this time. Like I said above, I used the WP coupler, but I had to sort of stretch the seal a bit to get it on to the thing to begin with.... I may have either stretched it too far, or it just simply rolled over when I knocked it home. I'm also going to start the motor up BEFORE i put the WP and everything back on just to make sure the leak is sealed. I had everything back together last time before I fired it up and noticed that the leak was still there.
If you are stuck on wanting a large marker for making that tool Wal-Mart has them right now for back to school stuff. I seen them in black today and I thought about this thread lol
FWIW I also use a socket
A link for anyone that ever needs one of these tools
Aluminum:
http://cgi.ebay.com/ebaymotors/_W0QQ...Q3aMESELXQ3aIT
[IMG][/IMG]
Delrin:
[IMG][/IMG]
Aluminum:
[IMG][/IMG]
Delrin:
[IMG][/IMG]
Ya I can hear what your getting at shbox you got this job covered...
This was just ment for the guys that dont and it sounded like there were some who wanted a source for this tool at a fair price. You keep using your socket as many times as you like.
