Sponsored by: DashLynx
Old 05-13-2016, 02:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
used simple green to clean engine bay, where did i go wrong?
Old 08-26-2011, 04:42 PM
vbls's Avatar
Default used simple green to clean engine bay, where did i go wrong?
ok first i rinsed it all down, then i sprayed it with the simple green, then i srcubed it with a toilet brush ibought, hard bristle. then rinsed and air dried with compressor, then wiped with rags
well after i got done wiping, i noticed the shock towers had some paint missing.. .??
is there a different cleaner i should use??
Old 08-26-2011, 05:15 PM
inssanity21's Avatar
the brush...... bad idea. simple green is harsh but shouldnt have done it, although i would have tested a spot where you couldnt see first. normal car wash soap would have been a better idea watching you dont get water all over the electronics
Old 08-26-2011, 06:03 PM
vbls's Avatar
so the simple green is ok if i dont use the brush?
Old 08-26-2011, 06:22 PM
bigj2717's Avatar
If you just let it sit then rise it. I just use soap and water with a brush. Sometimes simple green can take paint off just soaking you can dilute it with water just to be safe
Old 08-26-2011, 06:32 PM
TheSilverOne's Avatar
Did you dilute the simple green? The toilet brush is too aggressive.
Old 08-26-2011, 06:47 PM
vbls's Avatar
no i didnt dilute it, my bay is dirty, just rinsing wouldnt do it..i have to rub it, maybe shop towel?
Old 08-26-2011, 07:00 PM
RedHotG8's Avatar
Simple Green and a brush is not harmful at all. Evidently the paint was loose already and the brush made it flake off.
Old 08-26-2011, 07:37 PM
4get gto's Avatar
Disagree.......If you used it full strenght thats where it all went wrong..
Paint won't stand a chance.....
Old 08-26-2011, 08:03 PM
Mike454SS's Avatar
Simple green is also corrosive to aluminum if you let it sit too long...use Gunk Engine Bright...and a VERY VERY soft bristle brush if you use one at all.
Old 08-26-2011, 08:14 PM
Swiat34's Avatar
Save the brushing for the engine itself. Use a rag and toothbrush (at worst) to clean the painted surface.
Old 08-26-2011, 08:36 PM
RedHotG8's Avatar
I stand corrected, Simple Green will remove paint. Some people use it as a paint stripper. I never knew this and I'm shocked since I have used it on many cars. I'll definitely be more careful with it from now on.
Old 08-26-2011, 09:22 PM
Tiago's Avatar
yes I just simple greened my entire 94 car and it stripped the paint off of most of it LOL.
I did it on purpose btw
Old 08-26-2011, 10:07 PM
Conrad's Avatar
Can you post a pic of it for us?
Old 08-27-2011, 03:38 AM
Captain Double Post
BOBS99SS's Avatar
yeah i would like to see pics as well lol
Old 08-27-2011, 06:29 AM
vbls's Avatar
i would put some up, but i already used the touch up paint and painted it..
well im done with the simple green, whats next best thing??
Old 08-27-2011, 07:14 AM
stingrayj's Avatar
I have used simple green a number of times to keep my engines clean (as in maintenance). If needed I used a toothbrush to help lift dirt in certain areas. I would only let it set for about 15-20 seconds before rinsing it off generously. I have never had any paint issues. And I never diluted it. The main issue is to not let it sit too long. Simple Green is powerful stuff.
However, after reading this thread I may switch to something else.
Old 08-27-2011, 07:30 AM
4get gto's Avatar
He knows what he's doing..^^^^^^
Old 08-27-2011, 09:51 AM
Swiat34's Avatar
We use Simple Green to clean out 155mm howitzers in the Marines and I've never seen it strip the paint. And it's not like that military paint is anything special either.
Old 08-27-2011, 10:28 AM
9WhiteCamaro9's Avatar
I've used Simple Green but did not feel at all comforabtle so now I only use Engine Bright and if it has to take a little more work to get clean, I'll put in the little extra work just to make sure nothing like this happens.
Old 08-27-2011, 10:52 AM
82cetuner's Avatar
this is why you use the right products for your car, why have a nice car and then try to go out the cheep way to clean it? it makes me cringe when i see people washing there cars with a wash cloth and bucket of dirty water, and they use dish soap.
use the proper products to clean your ride, and for what it is worth a mr clean dry eraser works wonders on parts you can even clean your suspension with it. for under the hood I would use the same soap I wash the car with and some kind of non abrassive brush. I wouldnt put simple green on my car for anything, I dont even like using paper towels with windex to clean my windows
Quick Reply: used simple green to clean engine bay, where did i go wrong?
