where can i get my lt1 tuned
Old 08-26-2011, 07:57 PM
Luke1996ta's Avatar
Default where can i get my lt1 tuned
i live in north west ohio i need to get a tune u just put in a new cam and had my heads done now time for a tune anyone know where to take it in ohio???
Old 08-26-2011, 08:08 PM
Lawhead's Avatar
If you stuck with that CC502 I wouldn't even waste my time on a dyno tune
pcmforless
ION
email them
Old 08-26-2011, 08:09 PM
Luke1996ta's Avatar
should i even worry about a tune at all
Old 08-26-2011, 08:17 PM
Lawhead's Avatar
Yeah even a stock car will pick up from a tune but being as your set up isn't going to put out "Outstanding" numbers Id would just get a mail order tune and you should be more then happy with it
Old 08-26-2011, 08:18 PM
95sscamaro's Avatar
Pcmforless gets my vote
Old 08-26-2011, 09:49 PM
turtle93's Avatar
PCMforless did my mail tune piked up from 18 mpg to 22 will have new track numbers on the 9th of sept
Old 08-26-2011, 11:18 PM
z_speedfreak's Avatar
Ion's always come thru for me and his prices are way more reasonable than pcm4less, his company is madtuner btw www.madtuner.com
Old 08-26-2011, 11:27 PM
GR33N GoblinM6's Avatar
I had my tune done by MadTuner.com cheaper than pcm4less, infact pcm4less are the most expensive, so i dont know where the "4less" comes into play. Check them out 1st.
Old 08-26-2011, 11:32 PM
LSWHO's Avatar
The tunes are almost identical FYI.
Old 08-27-2011, 12:33 AM
transbird95's Avatar
I would still try to find a dyno. You put a lot of time and money into your engine why not get the most out of your work if you can. I have had a few different mail order tunes and I have had problems with all of them.
If you cant find a dyno, you might want to try LT1pcmtuning.com For what it's worth I have never had someone help me figure out all the problems I have had for so little. He has a few different options and a laptop loan option if you don't have one to data log.
Just googled dyno chassis in northern Ohio and there seems to be a few of them in your area. Not 100% if they all do lt1's though. but if your serious it shouldn't be too hard to find one.
Old 08-27-2011, 08:34 AM
WhitePhoenix99's Avatar
CincySpeed tunes LT1's in Ohio.. I would feel much better about a dyno tune than a mail order
Old 08-27-2011, 09:18 AM
Badazz 97 TA's Avatar
Your an idiot dude.
He just did H/C, its not like he just threw on a cold air intake. Who cares about numbers he might see, its about how his car will run and drive on a daily bases. Not everyone drives WOT 100% of the time. Atleast they will be able to see whats going on with his car instead of a guy guessing how a car will run. Not saying mail orders are "bad" but i would think he could get more out of it and peace of mind with a dyno, or find someone to drive around the street and tune it that way.
Old 08-27-2011, 10:13 AM
shix's Avatar
cincy speeds tuner does not have a good reputation locally. Just a heads up to anyone. Is Solomon from lt1pcmtuning.com any good?
Old 08-27-2011, 10:33 AM
Marc3.4V6's Avatar
According to Comp Cams, the 502 requires custom tuning and upgraded exhaust. At the very least get mail order. For even more power and driveability do a dyno tune. You'll just have to call local speed shops and ask if they have experience tuning LT1's.
Old 08-27-2011, 03:19 PM
solomon has been around forever and has one of the best reps out ther for a LT1 mail tuners
Old 08-27-2011, 04:21 PM
shix's Avatar
good. he has my pcm right now
Old 08-27-2011, 05:24 PM
Lawhead's Avatar
Originally Posted by Badazz 97 TA
Your an idiot dude.
LOL so 150 for a tune
Or 400 plus for a tune????
You can datalog and send it to your mail order tuner there you "idiot" so not sure where you are going with this kinda like you said I was wrong then backed up that I was right with your comment "Find someone to drive around the street and tune it that way". Its not like he's adding a Huge custom cam its a BABY cam he is clearly not interested in performance or he would have not went with that cam.
Pretty sure Joe picked up less then 15 HP on a SERIOUS H/C/I set up over a mail order tune to the dyno tune.......and COUNTLESS amount of people are running mail order tunes and running good numbers.
So you calling all them idiots ????
Old 08-27-2011, 05:27 PM
Lawhead's Avatar
LOL yeah DYNO TUNES ARE SOOOO MUCH BETTER FOR YOUR APPLICATION DUDE DO IT OR YOU CAR WILL BLOW UP!!!!!
Old 08-27-2011, 06:27 PM
Man-Crush Warning
Shownomercy's Avatar
Do you even own a running LT1 car?
Old 08-27-2011, 06:39 PM
I've read people gaining 30-50 hp from a dyno tune over a mail order tune. Even if you only gain a few hp it is still more power that you didn't have before right??? I guess some people just make sooo much hp that they don't care about every last bit.
Quick Reply: where can i get my lt1 tuned
