is a torque arm relocation bracket necessary?
Old 08-27-2011, 06:19 PM
Floorman279's Avatar
Default is a torque arm relocation bracket necessary?
is it a good idea to buy one if im putting out like 600 rwhp?
Old 08-27-2011, 06:32 PM
ranedoss27's Avatar
if you beat on the car alot, imo i would. its takes the stress off the tranny mount and transfers it to body. it also well help your 60ft at the track. i replaced mine with a tunnel mounted adjustable t/a. it lowered my 60ft and the only downfall is that if it has hyme joints it will clunk when you shift hard.
Old 08-27-2011, 08:44 PM
96TransAmboosted's Avatar
I agree with the above statement. Will take tons of load off the tranny. Will need to dial your pinion angle in.
Old 08-28-2011, 12:57 AM
01ssreda4's Avatar
With 600 hp, I'd say yes it would be a good investment.
Old 08-28-2011, 09:22 AM
ok thats what i figured....thanks
Old 08-28-2011, 11:06 AM
UMI Performance's Avatar
I agree as well, with that power you will want to consider it. Also if it is manual this adds to the risk of cracking the tail shaft.
I hope that helps!
Ryan
Old 08-28-2011, 11:19 AM
I hope that helps!
Ryan
yup m6.....goona do it
Old 08-28-2011, 03:48 PM
Here is ours if you would like to check it out: www.umiperformance.com/2207
If you would have any questions please ask. Thank you!
Ryan
