lsx drive by wire or cable
I'm doing a ls1 swap in my 94 vette and was wondering if I should go with the drive by wire or cable throttle body.What do you guys think is the best way to go.I have been doing searches on it but have been getting mixed reviews. thanks for the input.
LS1Tech Sponsor
If you dont have the TAC Module and Pedal, DBC will be considerably cheaper.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
As said previously, you should try and make sure you get the pedal and tac with the engine pullout to help keep cost down. If you are going to run DBC make sure you use a PCM with IAC drivers (Red/Blue PCM or GTO/Express Van Green/Blue).
FYI we have PCMs for $200 with standard tunes and DBC harnesses for $499. Still free shipping to LS1TECH.COM members.
Jon
PSI
__________________
Ebay Store
Ebay Store
Yes, and the Corvette TAC/Pedal setups are even more expensive than the truck.
Jon
PSI
Jon
PSI
I am putting a 5.3L LM7 that is bored to a 5.7L with 799 heads in my 85 Vette and I chose to stay away from the DBW. No other reason than just that i would like to keep it simple and I dont like the lag with DBW. When I touch that pedal i want my engine to respond immediately!
What setup are you using for the belt driven accessoried?
You can actually program the pedal response.
I actually have the opposite problem with my Nissan pickup, the TB is too responsive. I keep spinning the rear tires.
Jon
PSI
Jon
PSI
