lsx drive by wire or cable
Old Aug 31, 2011 | 10:43 PM
lsxc4vette's Avatar
Default lsx drive by wire or cable
I'm doing a ls1 swap in my 94 vette and was wondering if I should go with the drive by wire or cable throttle body.What do you guys think is the best way to go.I have been doing searches on it but have been getting mixed reviews. thanks for the input.
Old Aug 31, 2011 | 11:06 PM
the_merv's Avatar
Veteran: Air Force
I prefer the Cable ones..easier to tune with and work with IMO..
Old Aug 31, 2011 | 11:31 PM
lsxc4vette's Avatar
Cool thanks for the input.I like your avatar
Old Aug 31, 2011 | 11:45 PM
chuckd71's Avatar
Cable is certainly simple enough. I don't really see a downside to it.
Old Aug 31, 2011 | 11:52 PM
lsxc4vette's Avatar
Yeah,I won't have to get a dbw gas pedal too.I was'nt looking forward to getting one of those to fit in my car.
Old Sep 1, 2011 | 12:29 AM
the_merv's Avatar
Veteran: Air Force
Thanks..it helps get the point across when I tell people they are dumbshits..
Old Sep 1, 2011 | 06:56 AM
psiconversion's Avatar
LS1Tech Sponsor
If you dont have the TAC Module and Pedal, DBC will be considerably cheaper.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Sep 1, 2011 | 07:51 AM
lsxc4vette's Avatar
Jon
PSI
Don't have any of it yet.I was looking at prices for the tac module,not cheap.I thought DBW was the way to go,but thinking prolly stick wit cable.
Old Sep 1, 2011 | 08:17 AM
garys 68's Avatar
None of the newer ECUs have an IAC driver. You're going to need an 04 or older ecu/harness.
One advantage to DBW is the cruise control is built in. I've done 2 swaps with DBW, no problems. Just make sure you get a complete takeout with pedal and tac.
Old Sep 1, 2011 | 09:49 AM
chuckd71's Avatar
Cruise control would be nice.
Old Sep 1, 2011 | 11:14 AM
LS1Tech Sponsor
Yes, and the Corvette TAC/Pedal setups are even more expensive than the truck.
As said previously, you should try and make sure you get the pedal and tac with the engine pullout to help keep cost down. If you are going to run DBC make sure you use a PCM with IAC drivers (Red/Blue PCM or GTO/Express Van Green/Blue).
FYI we have PCMs for $200 with standard tunes and DBC harnesses for $499. Still free shipping to LS1TECH.COM members.
Jon
PSI
__________________
Ebay Store
Old Sep 1, 2011 | 11:28 AM
74novacustom's Avatar
Jon
PSI
With my DBW issues we might be talking soon about that. But i would like to keep my current setup.
Old Sep 1, 2011 | 03:08 PM
remauto1187's Avatar
I am putting a 5.3L LM7 that is bored to a 5.7L with 799 heads in my 85 Vette and I chose to stay away from the DBW. No other reason than just that i would like to keep it simple and I dont like the lag with DBW. When I touch that pedal i want my engine to respond immediately!
What setup are you using for the belt driven accessoried?
Old Sep 1, 2011 | 03:21 PM
WHen it was running, there was absolutely ZERO Lag, very fast Response
Old Sep 1, 2011 | 04:29 PM
lsxc4vette's Avatar
I'm using the belt driven accessory setup from a 97-04 vette.Their all the same from those vette years.But I don't plan on using ac.
Old Sep 1, 2011 | 05:39 PM
garys 68's Avatar
You can actually program the pedal response.
I actually have the opposite problem with my Nissan pickup, the TB is too responsive. I keep spinning the rear tires.
Old Sep 1, 2011 | 06:26 PM
1966 elco's Avatar
I just finished a 5.3 Flex Fuel swap into a 1966 El Camino, with DBW, and have zero lag as well. The response is immediate and my rear-end is paying for it. (LOL)
Old Sep 2, 2011 | 08:16 AM
Jim_PA's Avatar
DBW seems simpler to me as far as tuning and installation goes. No need to play with the IAC motor.
Old Sep 2, 2011 | 09:51 PM
thenova70ss's Avatar
Jon
PSI
You should take a Look at PSI Haenesses and PCM's i have them in my car and LOVE them all has worked Great from day 1 PSI is the way to go.
Old Sep 3, 2011 | 08:04 PM
robbyredneck's Avatar
dbw for my vote. cruise was like like 3 or 4 wires. cutting the adjustable height pedal to fit was a different story.
