Only getting 11 psi,comp 8079,370 ci
Old 09-08-2011, 09:14 PM
SPRAYED 01's Avatar
Default Only getting 11 psi,comp 8079,370 ci
Had the car on the dyno at speed inc today. With the boost controller at 80% duty (aem truboost) and an 11psi spring we are only getting 11psi. Just off the spring is about 7.5psi.
This is a forged 370 with stock intake and ported 241 heads,232/236 cam. Comp ball bearing,80/79 turbo with 1.32 ar and 3.5dp that goes to 3 then cutout.
Could this be back pressure, problem with controller?
Alex
Old 09-08-2011, 09:18 PM
SPRAYED 01's Avatar
Made about 600whp lock verter at 11psi. Thought that was kinda low for that turbo.
Old 09-08-2011, 09:34 PM
Restricted User
98Z28CobraKiller's Avatar
Torn diaphragm in wastegate
Old 09-08-2011, 10:12 PM
code4's Avatar
Wouldn't that give him more boost? I guess it depends on how his contoller is hooked up.
What did speed inc say? I would have had them try to trouble shoot it while there.
Old 09-08-2011, 10:30 PM
mike13's Avatar
From my own experience the duty cycle is deceiving, it might be at 80% but at 83% you might gain 2lb's. On my AEM I don't see a single lb of boost above the spring pressure until 70+ duty cycle
Old 09-08-2011, 11:14 PM
dudeman's Avatar
where is your boost/vac source for the boost solenoid? there isnt a check valve in your vacuum line anywhere is there?
Old 09-08-2011, 11:15 PM
eviltwin_1987's Avatar
What wastegate? What tranny?
Old 09-09-2011, 12:05 AM
MawneeC5's Avatar
I had a similar experience with the Tru Boost. Duty cucle seemed to give me about half that percent in boost percent increase(80% gave me 40% more boost) The controller worked fine, but the value wasnt a direct indicator.
Old 09-09-2011, 06:54 AM
SPRAYED 01's Avatar
Tial 38mm, flt level 7 65e with vig 3600 3 disc. No check valve, referenced from intake
Old 09-09-2011, 07:00 AM
dudeman's Avatar
what about a boost leak? check all of your connections and couplers. make sure they arent torn.
Old 09-09-2011, 08:09 AM
LS1Tech Sponsor
Slowhawk's Avatar
What catches me is the 7lbs on the 11lb spring. How is the controller hooked up?
Old 09-09-2011, 08:17 AM
mike13's Avatar
could be back pressure, also I wouldn't take anything for granted and would put low pressure and measure at what psi the valve opens. Could be as simple as a spring.
Old 09-09-2011, 08:47 AM
SPRAYED 01's Avatar
I've checked for leaks, could not find any. Is there any chance with a 1.32 going to a 3.5 dp but about 2 feet later going to 3 inch cause to much back pressure and stop it dead on making boost?
Old 09-09-2011, 10:21 AM
code4's Avatar
Although it is not an optimal set up I do not believe it would be the cause. I think you keep looking at the turbo as the problem but I think it is something else unless the turbo has damaged bearings.
Old 09-09-2011, 11:04 AM
rotary1307cc's Avatar
Something is goofy, that turbo should put the power down
Old 09-09-2011, 12:18 PM
If the vaccum lines on the controller are hooked up backwards, you will have these problems
Old 09-09-2011, 05:02 PM
compgto's Avatar
Hope you figure it out. This is the same turbo I have ordered.
Old 09-11-2011, 09:33 AM
SPRAYED 01's Avatar
Im going to have jim at speed inc try turning the controller up to 90%. If that doesn't work I was thinking of having him block off the waste gate referance, do a very quick run just to see if boost goes up.
Old 09-12-2011, 01:25 PM
SPRAYED 01's Avatar
Ok so from what I understand off the supposed 11lbs spring it only made 7lbs of boost but did 600whp.
So thats kinda good news but is really strange that it only made 7lbs with that spring.
Old 09-12-2011, 03:14 PM
blackmagicturbo's Avatar
Aircleaner? Seems some people are having problems with air cleaners being restrictive ?
Quick Reply: Only getting 11 psi,comp 8079,370 ci
