341 rwhp... i was expecting more
Hi guys, i have a 2004 gto with a stock 5.3 engine with ls1 heads on it and am running the STS Turbo kit at 10psi, the car made 341 rwhp and i feel it should make much more.. what rwhp should i expect? my AFR is 10.3 at wot with meth
any ideas...
any ideas...
dyno was loaded perfect, 4000lbs for a 2004 gto, i have the a4, should i run without meth? im running at 5600rpm with peak hp at 4600rpm.. something isnt right.. no detonation all around with meth,
i dont know about the converter, timing was 14 degrees, on the WOT area of the spark table, stock manifolds with the STS Turbo kit which has 2.5 inches to the turbo i think..
the recorded run i with the tuner, ill try and get a hold of it tomorrow, what exactly do you mean by blowing through my converter? i have stocks ls1 valve springs as i do not exceed 5500rpms and i don't think i have valve float
my boost reference is in the vacuum line that goes to the brake booster and my boost gauge is also connected there, that is where the STS kit fittings are provided.. should i move it the intake? would that make any difference? i seem to be hitting 10psi at around 3-4k rpms which seems normal...
Aren't the 5.3's like 9.5:1 with stock heads anyways?? Defenitely seems off my 4.8 with only a ls1 intake and the early ls2 can and springs makes 490 at 12 pounds and at about 5800rpms, 10.5lbs was 469whp if I remember correctly on 93 octane no meth and timing in the 12-15 degree range depending on how much the burst knock steals lol
Valve springs defenitely seem possible, and meth just seems overkill, my afrs were in the 10.4 range also, so I'm sure you have something holding you back..
