just got 18 19 c6 wheels rear tire size help
Old 09-11-2011, 09:50 PM
payanhilario's Avatar
Default just got 18 19 c6 wheels rear tire size help
Front ones bolt right up rear rims have no tires my friend is selling 305 /35/ 19 will does tire fit and what size adaptor do i get with does wheels thank u
Old 09-12-2011, 04:48 PM
zacht's Avatar
its not ideal...but im running 305/30's on my oem c6z wheels...if your running the regular c6 wheels...(19x10) i think it should work fine...your getting them at a great price right?
i would bolt up the rears and see what kind of spacer you need, but iirc you will probably need around a 1in spacer (oe wheels...i think)
plenty of threads with this info...
Old 09-12-2011, 06:13 PM
I got them for 270 with no rear tires and I found 305/30/19 almost new for 40 bucks a pice so what size adaptor do I order
Old 09-13-2011, 12:55 AM
bwilde86's Avatar
Just ordered a set of wheels same size. Very interested in tire size and spacer needed
Old 09-13-2011, 10:14 AM
soo what size spacer did you get people say 1.0 and 1.5
Old 09-13-2011, 11:13 AM
bwilde86's Avatar
Didn't order any yet. Waiting til rims get here to figure that part out. Just ordered curious what size tires people run on 19's
Old 09-13-2011, 12:14 PM
What tire u gonna run
Old 09-13-2011, 12:41 PM
bwilde86's Avatar
Nitto 555r not sure on size tho. Probably around 305-315 I would imagine
Old 09-13-2011, 01:06 PM
97 FiReBiRd's Avatar
If its the OEM C6 Wheel i just ordered mine in the same size. Needs a 1.25 spacer for the rear, fronts fit correctly. If its an OE Replica wheel I believe it bolts straight on without spacers.
Old 09-13-2011, 03:30 PM
bwilde86's Avatar
Its from oewheelsllc.com. what's the difference between the two?
Old 09-13-2011, 05:29 PM
Douchebag On The Tree
justin455's Avatar
OE wheels is a company that makes wheels with oem designs, but with the proper sizes to fit fbodies.
Old 09-13-2011, 06:33 PM
bwilde86's Avatar
So just different offset?
Old 09-15-2011, 11:45 PM
Default More or Less
Remember OE Wheels makes replicas, OEMs are the ones from the factory so as stated above they do not need spacers as they are fit for our cars, the OEM Corvette wheels are designed for a Corvette, so they need modifications to fit our cars
Old 09-16-2011, 08:21 AM
LS1Tech Platinum Sponsor
OEWheelsLLC's Avatar
our 19" wheels will need an adapter to fit. the size of the adapter is all depending upon your individual vehicle.
__________________
Nelson W. OE Wheels
Customer Service Rep. & Sales
nelson@oewheels.net
Give us a call for fast service!
(866) 273 - 3651
Check out our wheels!
Quick Reply: just got 18 19 c6 wheels rear tire size help
