eps 226-234 cam and tfc 215s
Old 09-13-2011, 07:00 PM
spiro27's Avatar
Smile eps 226-234 cam and tfc 215s
im about to start my bild soon on my 01 t/a 6 speed. so far i have the eps 226 234 cam ls7 lifters ls2 trays and ls2 chain tfc 215 heads cosmetic 51 thou head gaskets tfc pusthrods fast 102 intake arh 1/78 headders and y pipe. this is my first non stock cam replacement on these motors. done it a few times but just on pickups and suvs newer style for cam destryed by lifter. my question is do i have to degree this cam and what difference will it make if i do or dont. i will prob need a ajustibe timming set too. how bad is it to degree cam in car? is it worth doing. will i be okay with ptv clearence. should i mill heads. i was tild to put them on out of the box without doing anything to them.. what power do you think the car will make. what injectors shoul i get for this setup. i gess i will get 102mm tb too. thanks for the help and advice thanks.
Old 09-13-2011, 09:04 PM
nastychevelle's Avatar
Always, i mean always degree the cam.
Old 09-15-2011, 05:20 AM
spiro27's Avatar
is it hard to degree can in car
Old 09-15-2011, 05:41 AM
lsxc4vette's Avatar
I totally disagree.I put in plenty of cams in Lt1 motors and LS1 motors and never degreed the cam.If you don't degree the cam you could leave a few Hp on the table.I would degree the cam in a GEN1 motor.
Old 09-15-2011, 06:11 AM
redtail2426's Avatar
just degree it,its simple,cheap and only takes 10 minutes,skipping this step is like banging a chick without a rubber,you might be sorry,and you might be okay,but i wouldnt do it
Old 09-15-2011, 06:52 AM
please inform me on how its any different to degree a cam for a gen 1 engine compared to a gen 3 engine.
Old 09-15-2011, 10:00 AM
usafws6's Avatar
Thatll be a clean 470rwhp with a manual.
Old 09-15-2011, 09:16 PM
spiro27's Avatar
what tools will i need is there any rite ups on how to degree a ls1. will i need an ajustible timming set?
Old 09-16-2011, 06:03 PM
your going to need a degree wheel, a piston stop and a dial indicator.
http://www.youtube.com/watch?v=S7ZzYaMVi00
Old 09-17-2011, 06:53 PM
spiro27's Avatar
so i gess i will need to get a ajustible timming set and a cam degree kit. without an ajustible timming set its pointless
Old 09-18-2011, 12:05 PM
garygnu's Avatar
try to degree it with your current timing set ,if it don't work then get a adjustable timing set.
Old 09-18-2011, 03:41 PM
m1key99WS6's Avatar
You may not need an adjustable set, when I degreed my cam it was 1 degree of and I just loosened up the timing chain and move it a little and it was fine afterwards.
Old 09-18-2011, 04:22 PM
MonmouthCtyLS7's Avatar
Good analogy
