Any experience low hp due to dented in dp?
My 3.5dp had to be beatened down alittle to fit the sway bar. Its not to bad but im having low hp issues on the dyno.
Comp 80/79 billet wheel,1.32ar 3.5 dp for about 3 feet then 3 inch then cutout.
With a forged 370ci 232/236 cam through a locked converter and 9 inch at 7lbs its only at 490whp and 545ftlbs. The main issue is that it peaks at 5100rpm.
Tuner thinks its may be a restriction in the turbo system.
I seriously don't think that your DP is an issue. We tested the back pressure on my stock LS1 with a 3 " downpipe (no cut-out) on the TC78 with .96 a/r. on 8 psi and I flow all the way past 6000 rpm. Could be your muffler...it you have one
