camshaft help
camshaft help
Bought a 2000 ss yesterday with about every bolt on and this Cam is It good lol
Thunder raceing custom camshaft
Duration intake 232.0 exhaust 235.9 valve lift w/1.7 rockers intake. 617 exhaust. 601 lobe separation angle 113.5
I got a 99 Hugger Orange Camaro SS Auto trans. I bought a Comp Cam 223/231 610 I was wondering what stall should I go with?would a 2800 Stall be good for my application?
What we mean by gear ratios is what your final drive gear ratio is for your drivetrain. A steeper gear i.e. 4:10, 3:73 will have better acceleration but lower top speed. A shallower gear i.e. 3:23, 3:08 will have less acceleration but a higher top speed. The gear ratios are the ring and pinion located in the rear axle housing of rear wheel drive vehicles. I hope this helps.
Any of LS1tech sponsors will have the gear setup you are looking for. I see that you have an auto car and I would definitely doing a stall first over gears. You will see a much better gain.
Nice thanks for the help. My transmission went out on me so yeah I'm planning to get all that stuff done. Is it worth the money buying this transmission. http://www.bmracing.com/PRODUCTS/GM/...ne-converter_3
That's not a bad price for that B+M trans. I would however call Performabuilt and FLT trans and talk over your options with them as well. They are very reputable 4l60 builders here.
