Help me identify this cam please...Numbers etched by hand
Old 09-27-2011, 03:26 PM
adham's Avatar
Default Help me identify this cam please...Numbers etched by hand
Hello,
I just pulled my cam and I wanted to know the specs on it. The cam went bad and messed up the lifters too. I bought the car with the cam in it already and the previous owner didn't know the specs either. It has some hand etchings on the bottom of it that read as follows:
3724R/3726R
HR 114+1
Then it has the letters CC etched which I assume stands for Comp Cams.
Lastly, F6730-05 is etched as well.
Thanks for the help!
Old 09-27-2011, 03:34 PM
Whiteaw57's Avatar
those first numbers look like Lobe reference numbers from comp.
the second looks like LSA and advance
that last number i dont know
Old 09-27-2011, 04:10 PM
ss454327's Avatar
Comp XE-R lobed cam
228/232 .588/.595
Old 09-27-2011, 04:34 PM
LS1MCSS's Avatar
Here is a link to Comps master lobe list, in case someone else wants to look one up.
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Old 09-27-2011, 04:48 PM
adham's Avatar
Wow, thanks for the info guys!!
Old 09-27-2011, 05:07 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Originally Posted by ss454327
Comp XE-R lobed cam
228/232 .588/.595
He nailed it, 114LSA 113 ICL.
It was ground by Comp in 2005
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-27-2011, 05:13 PM
adham's Avatar
What kind of power would a cam like this put down on a 2001 Corvette Z06 with stock ls6 heads and intake and bolt ons?
Old 09-27-2011, 05:21 PM
I'd expect it to give you about 40-45rwhp at peak over the stock cam. If you search "228/232" in the dyno results section, I'm sure you'll find quite a few threads with graphs!
__________________
Old 09-27-2011, 06:41 PM
Whiteaw57's Avatar
Matt when we order custom cams and such is the LSA and ICL determined off of those lobe reference numbers or is it something that is determined based on how they cut the cam?
Old 09-27-2011, 09:25 PM
ss454327's Avatar
The HR 114+1 is what gave the LSA and ICL. Those aren't determined by the lobe number.
Old 09-27-2011, 09:29 PM
Whiteaw57's Avatar
Yeah I realize that. Is that just determined by the way they cut the cam?
Old 09-28-2011, 01:04 AM
adham's Avatar
Now that I know what cam it is and the specs, I need some help picking out a new one. What would be an upgrade to this cam? I'm looking for something a little bigger but not extreme. I'd like to be in the 420-430 range. I don't want a lift much higher than .600
I was thinking about the tsp 233 239 cam on a 112 lsa. Would that be a good upgrade or should I go with something else? I'm open to all suggestions.
Thanks again,
Adham
Quick Reply: Help me identify this cam please...Numbers etched by hand
