Difference in tune using 93 octane w/o ethanol?
Old 10-05-2011, 01:35 AM
LilJayV10's Avatar
Default Difference in tune using 93 octane w/o ethanol?
I had a quick question. Would there be a difference in getting my car tuned using 93 that doesn't have any ethanol in it?
The reason I ask is I'm going to stop using gasoline w/ ethanol in it in my small engines, lawn mowers, chain saws, etc. because it wrecks small engines.
My car is a 00. H/C/I/E with about 11.5:1 compression.
When I had my car dyno tuned my tuner pretty much set the A/F to 13:1@WOT. Someone commented in another thread of mine that ethanol blended fuel has a different A/F ratio than gasoline without.
Any opinions?
Jason
Old 10-05-2011, 07:52 AM
Old Buzzard's Avatar
"When I had my car tuned my tuner pretty much set the A/F to 13:1. Someone commented in another thread of mine that ethanol blended fuel has a different A/F ratio than gasoline without."
13:1??? @idle, WOT, etc??
The ethanol problem is the pump signs say "up to 10% ethanol"...
I tried the 14.33 as stoich, and tried 14.63...Saw little difference, & left it at 14.63.
Old 10-05-2011, 08:56 AM
LilJayV10's Avatar
LOL. @WOT. Sorry I didn't specify.
Old 10-09-2011, 12:45 PM
Higgs Boson's Avatar
Have you found a place that still sells E0?
Old 10-09-2011, 01:20 PM
LilJayV10's Avatar
If you mean gasoline with no ethanol yes. There are three places in town.
Old 10-09-2011, 01:32 PM
3.8redbird's Avatar
There are 3 in my town alone
Old 10-09-2011, 04:52 PM
Damn none here that I know of.
Old 10-09-2011, 05:07 PM
Rhino79's Avatar
Probably going to have to run a little less timing advance and tweak the wot fuel a little, but other than that, should all be good. You are still going to target the same fuel number, most widebands read lambda and display in afr, so the target number of 13.0 will be the same if that is what is desired..
Old 10-21-2011, 02:07 AM
LilJayV10's Avatar
Interesting to know. Thanks for the reply.
