Pontiac GTO 2004-2006 The Modern Goat
header install
Old 10-07-2011, 10:12 AM
massillongoat's Avatar
Default header install
has anyone got the header out of the drivers side out with out popping the power steerings lines off?
Old 10-07-2011, 05:53 PM
700rocket's Avatar
Yes you can install/remove without removing the lines.
Old 10-07-2011, 06:28 PM
batboy's Avatar
It's easier if you remove the lines. I've heard it can be done otherwise, but it's a major pain.
Old 10-07-2011, 08:39 PM
96WS6guy's Avatar
I did it without removing the lines. Just unbolted the entire steering box and the adjacent bolt on the other side. Then pushed all that toward the passenger side (do your best not to actually push on the wheels as that increases the chances of needing to get your alignment adjusted). It cleared up enough room to get the DS header in.
Old 10-09-2011, 11:34 AM
O-FiveCC's Avatar
I've heard its a matter of what header's you are actually using. With Pacesetter's it seems you have to remove it all. That's just what I've read. I removed it all for my Pacesetter's, and it was still tight. Threading those lines does suck.
Old 10-10-2011, 07:29 AM
carl06gt's Avatar
is there a write up anywhere on installing headears? im new to the v8 world
Old 10-10-2011, 07:00 PM
96WS6guy's Avatar
I used a combination of these two threads and a little of my own fandangling to get it to work how I wanted.....
http://www.ls1gto.com/forums/showthread.php?t=288135
http://www.okgoatherd.com/cgi-bin/ya...m=1307338490/0
Old 10-10-2011, 10:12 PM
carl06gt's Avatar
thanks. looking forward to buying a set and installing them in the spring
Old 10-11-2011, 09:07 AM
regardless of how you do it its a pain
Old 10-11-2011, 11:21 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Yep. The least painful for me was to just lower the rack.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Quick Reply: header install
