jlee29
10-09-2011, 09:51 AM
1991 Nissan 240sx
RESULTS: 422rwhp 382ft.lbs (With tires spinning some)
Mods:
LQ4
799 heads Stock
LS6 intake
28.8lb injectors (98% cycle duty I know i'm due for larger ones with future mds)
MS4 cam
Arp rod bolts
P&P TB
Ud pulley
Long tubes
3" duals into> 3 1/2 single exit straight through muffler.
Aluminum Flywheel
Ls7 clutch
4.08 gears
T-56 (out of 02' SS)
CAI With too small of filter :bang: (Tuner said I could pick up some power with a larger one)
I havent been to the track yet, i'm building an 8-pt cage currently then I'll see what times I can pull. Car weights ~2800lbs loaded.
http://www.youtube.com/watch?v=gtc7VlUrIs0&feature=youtube_gdata_player
The tires were spinning a little and I believe thats where the waves come from, tires were smoking a little and hot after a pull..
http://farm7.static.flickr.com/6226/6226625772_088d07a44f.jpg (http://www.flickr.com/photos/55665137@N05/6226625772/)
Mods:
LQ4
799 heads Stock
LS6 intake
MS4 cam
Arp rod bolts
P&P TB
Ud pulley
Long tubes
Aluminum Flywheel
Ls7 clutch
4.08 gears
