LS2 L92 Heads/Cam - Missing Anything?
It's my first foray into the LS world, and I want to make sure I don't get my daily driver apart and find out I'm missing something. I have an 06 cts-v (58x LS2) that I want to swap to l92 heads and a cam. Here's my list thus far.
L92 Ported Heads (SDPC probably)
Offset Rocker Arm (8x)
Rocker Arm Support (2x)
Head Gasket
Timing Cover Gasket
Timing Set (ordered from Yank)
Water Pump Gasket
Cam (222/230 Pat G + EPS otw)
Pushrods (Hardened otw)
Balancer Bolt (ARP)
LS3 Intake Manifold
LS3 Map Sensor (will require an adapter and whatnot)
Have I missed anything? I'm sure this has been done a million times.
Head Gasket
Timing Cover Gasket
Water Pump Gasket
Balancer Bolt (ARP)
LS3 Intake Manifold
Injectors & fuel rails, and appropriate injector harness adapters depending on what injectors you choose.
I'd also recommend a pushrod length checker so you can determine the correct pushrod length.
I am planning to use an LS3 intake manifold w/it's factory rails and injectors. I was under the impression that these would plug directly into the harness that I already have.
