02 wrx fs/ft CT
02 wrx fs/ft CT
Year: 2002
Make: Subaru
Model: Impreza
Price: $9000
Mileage: 123000
Private or Dealer Listing: Private Listing
Location (State): CT
Color: Silver
Transmission: Manual
Drivetrain: 4WD & AWD
https://ls1tech.com/forums/vehicle-c...w-rebuilt.html
i will include everything except the 20 inch wheels and sound system
how much $ will i need to fix the wrx? or to add what it needs? is it clean title?
what does the car have currently right now installed?
is this car standard? it comes with turbo? or turbos? im new to this cars sorry
it comes stock with turbos?
what do you mean with it had?
with 123k on the body I had a hybrid motor (jdm v7 forged 2.0L with brand new usdm Wrx heads) prfessionaly built and installed with a 20g Turbo and aps Turbo back exhaust the car only needs bigger injectors fuel pump and a tune to make its potential power the car is running fine with a manual boost control or to keep it from over boosting right now but I have a bay on the way and I have t cut my losses and sell the project preferably sooner then later cosmeticly its not the prettiest thing but its a running Wrx with a forged semi closed deck jdm block and a good Turbo capable of making more power then a usdm sti
Being a Wrx it comes stock with a Turbo but I put a larger one in when we did the new motor and all it needs to make better use of the bigger Turbo and forged block is an upgrade to the fuel system and a tune to match it
so how much $ would you need to fix it with what it needs in order to be tuned the right way with what it has to work correctly
any pics of inside and motor...how much did the aftermarket turbo cost and the block? do u still have the stock turbo?
what difference does it make on performance? any times in 1/4 mile or hp numbers?
