Qverlap question
Old 10-19-2011, 01:20 PM
Whiteaw57's Avatar
Default Qverlap question
A search really didn't get me what I am looking for. I think Im about 80% there learning about cams and cam theory. I get the straight forward stuff, now its onto the tougher questions and just for my general knowledge and curiosity I have a question about Overlap in a Camshaft. I see it referred to as what gives the chop/lope I.E more overlap means a rougher idle. I also understand overlap refers to the time in degrees of rotation that the intake and exhaust valve are both open. My Question is what is the effect of a negative overlap?
I recently did a cam swap from a -1 degree overlap cam 224/230 114lsa
to a +15 degree overlap cam 238/240 112lsa
The reason I ask is because however my idle is more radical is wasn't what I expected going from the first cam to the second. They're fairly close sounding.
I have a bunch of questions to add to this main one but maybe if someone could explain what exactly overlap will theoretically change I might can gather from that what I am trying to figure out.
Thanks in advance. If I need to stop taking up space with my theory questions just let me know and I will delete this.
Old 10-19-2011, 02:02 PM
MM98's Avatar
In short:
Less overlap, more low end power & better idle quality
More overlap, better mid-top end power & worse idle quality.
Old 10-19-2011, 04:18 PM
Whiteaw57's Avatar
Right i get that much. Im just wondering how I had the nice choppy race sounding idle with the -1 overlap
Old 10-19-2011, 05:29 PM
MM98's Avatar
The 114 lsa has effect on idle as it lowers vacum vs the stock 116 lsa... Did you use the same tuner on both cams? A good tuner can make a big cam sound pretty tame.
Old 10-19-2011, 06:26 PM
Whiteaw57's Avatar
I understand the LSA and all. Im just not understanding a negative overlap. or what I would interpret as one degree short of actually overlapping. I actually asked him to make it choppy for me. And it is much choppier than it was just not right off that bat. You have to really listen to it and on video it sounds very close to what it did before. Thats not a problem just curious why since I added 16 degrees of overlap
Old 10-19-2011, 10:56 PM
99Bluz28's Avatar
Was the idle speed set to the same rpm for both cams?
Old 10-20-2011, 09:18 AM
s346k's Avatar
the tune can play a big role on how radically a cam will idle. there is no reason a cam with -1* overlap should, would, or could sound like one with 15*. the cam with more overlap will lope harder and at higher rpms, as well. instead of smoothing out at 1300 or whatever like the old one did it probably sounds pretty damn rowdy.
Old 10-20-2011, 10:12 AM
Higgs Boson's Avatar
I agree. You can tune a 15 deg overlap cam to sound like a 0 overlap cam. You can also tune the 0 overlap cam to be very smooth, yours just wasn't, apparently.
there are lots of timing and airflow tables that are used to make a car idle smoothly. bottom line is, All things equal, the bigger cam will have more trouble holding a steady idle RPM, and that's all lope/chop is.
Old 10-20-2011, 11:46 AM
Whiteaw57's Avatar
I think its a case here of a better tuner (my guess tune with the bigass cam drove better than the final with the small one) a few more RPM at idle, (i think its roughly about 100 RPM higher), and maybe I'm just crazy and want the thing to hit like my life long goal of building a motor to sound like a Nascar car. Which I'm in the process of doing btw. It definitely pulls harder and longer. It definitely drives a bit bigger. and revs quicker also. Not sure it thats in the tune also. Could be due to coming off of a higher idle speed im guessing. Im not complaining at all by any means more just extremely curious as to just exactly how overlap works
Old 10-20-2011, 02:00 PM
darkvader0's Avatar
The only thing I wanted to add was to make sure you are aware that the -1* overlap is measured at 0.050" lift. At 0.006" lift the overlap on that same cam will be much higher. In fact, I think even the tamest of cams will have a pretty significant positive overlap at 0.006.
Old 10-20-2011, 02:06 PM
s346k's Avatar
Overlap itself is the occurance of both valves being open at the same time.
Old 10-20-2011, 04:25 PM
Whiteaw57's Avatar
I used an overlap calculator but the math is not dependent on a location on the cam. I think you're thinking here of duration
Old 10-20-2011, 04:42 PM
garygnu's Avatar
+ cam over lap degrees,how many degrees both intake and exhaust valves are open at the same time bleeding off cylinder pressure.
Old 10-20-2011, 05:26 PM
Whiteaw57's Avatar
Yeah i get that. I guess im just overthinking this too much. Does overlap equal power? or does it just shift the RPM band up? Or does it do both? haha
Old 10-20-2011, 07:47 PM
s346k's Avatar
both.
http://www.chevyhiperformance.com/te...ing/index.html
read.
Old 10-21-2011, 11:36 AM
Whiteaw57's Avatar
youre the man haha
Old 10-21-2011, 02:59 PM
99Bluz28's Avatar
If the idle is set even 100rpm higher than before that'll make a noticeable difference in the lope you hear.
