Fan Combinations for FI Cars
Ok, I know it's an LT1 car, but the principle is the same. Stroker, turbo, decent HP numbers, yadda yadda yadda. Running in a stock radiator, stock location w/ a/c condenser, stock shroud with recommended cheapy low profile fans that are used in kits with vertical radiator turbo kits. Intercooler is horizontally mounted in front of the radiator crossmember, so there's very little restriction in the airflow going up to the radiator, and certainly less than if I had the radiator standing upright.
Car was running at about 210-220 on a 55-60* day today. Too warm for my taste.
So I was wondering, how much do you think it would help if I were to install a pair of decent pusher fans on the front of the A/C condenser for a pusher puller four fan combo for airflow? Crazy? Bad idea? Good idea? Other ideas?
I had 2 pullers w/ 1 pusher when radiator/condensor were together like factory has it, always ran a lil warm for my taste too.
My Fix:
Cut front of rad support, moved condensor down & foward 2"+ installed pusher on radiator between the rad & condensor. temps dropped 15-20+ degrees.
(you have to bend a/c hard line straight & small bend at end to make line longer to reach)
My Fix:
Hey, you could also make the car run cooler, but it seems you won't. Good luck with the pusher puller setup. When it doesn't work and you want it to run cool tell us how standing up the radiator works. Wanna keep it looking factory as possible? Take the turbo off it then. I don't mean to sound like a dick, but hate when people ask for advice and then don't like the answers they hear.
Could car less if you take my advice. Just hate to see you waste your time on something I already know about. I have spent a bunch of money figuring it out the hard way. I did the stock radiator with pushers, pullers, split pusher pullers and it didn't do what I wanted. I ultimately went with a bigger radiator and a good puller setup. The stock core is only a single row and doesn't have a whole lot of capacity. The more water you can put in the system the better.
big front mount single turbo car here. nice thick aluminum aftermarket radiator leaned wayy forward. summit racing shrouded dual pullers. stock waterpump. car will idle mid 190's all day
Here are the pushers I bought. My car isn't running yet, but many others have used these to push through a condenser and radiator and had no cooling issues.
http://www.summitracing.com/parts/DER-16925/
Thats what im using. Koolrayz and Tally have used them without a problem too
It's a Hypertech 160* thermostat, Meziere EWP, stock radiator, non-stock pullers mounted in the stock shroud. Fans are set to come on a 180* and go off at 170* IIRC.....I'd have to pull the tune off the XFI and look at it.
I am running a 10" puller on top of the intercooler also.
210-220 is normal for a stockish LT1. I haven't run over 190 for a long time until I crowded up the engine bay.
