What size bolts for LCAs & PHB?
Anybody know what size bolts are used for LCAs & PHB? I have to go pick up some grade 8 hardware tommorow and I figured I'd pick up hardware for my LCAs and PHB at the same time. The car is still in storage so I can't crawl under it and see. I thought that they were 7/16" or 1/2" but, I need to know the lengths more than anything.
Thanks,
Andrew
Thanks,
Andrew
Just reuse the stock bolts. They taper down and you'd have to buy new bolt from the dealer at $3 a piece at wholesale and another $3 for the nuts for this custom size. If you go with a grade 8, you will have to enlarge the wholes on the mounts to fit the straight 3in long, 1/2 in. bolt.
Only the PHB uses tappered bolts right? Does 4" length sound right for the LCA's or is it 4 1/2? I'm not only replacing them for strength but also looks. Rusty hardware drives me nuts (no pun intended), so I figured I would replace it all as I replace suspension parts.
I'm not positive, but I believe all of them taper down. The stockers are just as strong as any other one you'd buy as they are a grade 8.8 metric. Paint them if you want them pretty.
I just checked some sources and these bolts don't look tapered: http://www.lmperformance.com/2875/2.html
So now i am a little confused.
They don't need to be tapered. The stock bolts are metric, and if you buy new metric bolts you DON'T have to enlarge a damn thing. It is, however, hard to find metric bolts with the same skirt as the stick ones. I had to use separate washers.
I think BadAndy is right for the LCAs, but you definitely would have to go and enlarge the PHB if you want to run a non tapered bolt as the two holes are difference sizes. A correction to my statement above - the stockers are a grade 10.9 metric = grade 8, so nothing to gain by switching.
Wow, thanks for all the info guys. Maybe I'll just invest in an at home plating system. Although, it would be a hell of alot cheaper to run a drill through the mounts. My LCA's and PHB are both double rod ends and 1/2" bolts fit through the sleeves perfect.
