New hood, question on hood pins
Yeah it will be painted but after the holidays lol. Body shop put the hood on and tried everything. It doesn't take much force at all to make it sit even. Good to know that set of hoods pins will fix this. Extra added safety + making hood sit even = win.
Thanks
Thanks, this hood fits like stock minus that one little area so I'm actually quite happy with it. I know fiberglass is NEVER perfect regardless of the company, but it can be damn near perfect because of the company you pick..........................VFN all the way
UNDER PRESSURE MOD
Try lowering the stop that's under that corner even lower than normal height, then place some weight on the hood for a while with a light amount of heat, like leaving it in the sun for a while. That might help just enough to get it to lay flat.
I have the aerocatch hood pins which are awesome if it's something you like.
Captain Double Post
I really think that is a issue with vfns mold.if you look at the 3 inch SS Hood they all have that.i thought it was only with the 3inch but maybe that is becauce its more noticeable on that Hood.i would try adjusting it a lol more but even with everything i did i could not fix thatpart
This illustration Should Help, The ls-1 Hoods Pivot like a Teeter Totter on the Center latch, so for example if the Drivers side sticks up, loosen the center latch and move it slightly in the direction of the drivers side, if the passenger side is the one sticking up just move the latch towards that side
Oh sweet, thanks!!!! I didn't realize this haha
