Fastest stock bottom end 6-speed?
Old 10-29-2011, 06:37 PM
StangEaterSS's Avatar
Default Fastest stock bottom end 6-speed?
How fast is the fastest stock bottom end 6-speed f-body? I just went 10.20@134 with my heads/cam car on 200 shot, six speeds inc built t-56. might have a bit left in it. tryin to dip into the 9's. anyone with a legit stock motor with only heads/cam power adder ever go 9's?
Old 10-30-2011, 10:41 AM
223HAWK's Avatar
Dang thats moving out! I plan to do a big hit on mine next spring! Whats the weight of that beast?
Old 10-30-2011, 11:11 AM
3,460 with driver
Old 10-30-2011, 01:16 PM
z_speedfreak's Avatar
joe whats his face from the old six spds inc I think still holds the record for fasted 6spd but his is faceplated and is missing some gears. fastest true stock form t56 is tanner bosnali https://ls1tech.com/forums/member.php?u=4939 and your nearly 2seconds behind his LT1
Old 10-30-2011, 01:19 PM
none of these cars are stock motor. this car is straight from the showroom bran new I've owned it for years I put heads and cam on it and spray it. the car is stock as hell. I'm talking about stock motor ls1 f-body's. I could easily put a new motor in the car and go low 9's with this trans. that's not the point. I want to push the stock motor as far as possible with a t-56.
Old 10-30-2011, 01:23 PM
Ooo mis-read the tittle lol
Old 10-30-2011, 01:38 PM
Joe actually built my trans. I've been to the track with them and i've seen his 6-speed car go 8.70's in person. fastest banger car i've ever seen. but its far from stock.
Old 10-30-2011, 05:13 PM
223HAWK's Avatar
Yeah stock bottom end..Have you ever put a set of good rod bolts in?
Old 10-30-2011, 05:17 PM
223HAWK's Avatar
Iv found a guy local that seems to know what hes doing with a T56..just wondering what you guys are paying to get um rebuilt? I know mines going to need it if I up the jets lol
Old 10-30-2011, 07:23 PM
joe and amber charged me $1,200 a few years ago. but they closed up shop and dont advertise doin trannys anymore. i'm sure if you live close they will do it in the garage at home for you. just not under the business name. Finish line trans is right by me. chuck at finishline trans ( FLT) quoted me $1,900. they are definetly the next best place hands down. but $1,900 was too steep of a price.
Old 10-30-2011, 07:30 PM
too lazy to pull the motor half out to get the pan off and do it. i just spray it and hold on. if it pops, a bigger better motor will go in. this stock one is on borrowed time anyway.
Old 10-30-2011, 07:34 PM
223HAWK's Avatar
LOL Same here..I may do rod bolts this winter but not sure. What kind of fuel system you running,. I just did a stand alone and a Walbro 255 so I should be safe of fuel! lol I bought a spare short block a few months back for the "just in case"
Old 10-30-2011, 07:48 PM
I have a walbro 255 in tank with stock lines, stock rails and FAST 36lb injectors. I run 93 pump gas. the kit is a dry nitrous outlet singe nozzle. ( made the kit for like $200-$250) the car was tuned strictly for spray. it runs a bit rich on motor because the MAF was not correcting fuel enough, but we got it running hard on the bottle.
Old 10-31-2011, 01:22 AM
ditto way back in '05, came to $1500 cause I needed 1 new gear and had some extras added. and neither mine nor stangs(im assuming) were stock rebuilds fyi
Old 10-31-2011, 03:24 AM
BES Stroked Nova's Avatar
list needs updated.... I took the true 6 speed record.
Old 10-31-2011, 11:33 AM
nice, congrats! when was this? taner has to step it up a bit! (sorry I'm an LT1 guy)
Old 10-31-2011, 01:13 PM
lsx shootout. should be a vid in the list
Old 12-18-2011, 08:05 PM
Zmg00camaross's Avatar
So do we know who went fastest on stock bottom end 6 speed?
Old 12-18-2011, 09:54 PM
according to the list that was posted long ago in the manual trans section, speedyws6 went 10.02 with the stock bottom end and nitrous. thats the fastest that is recorded on a list. I went 10.20 which would be 2nd fastest recorded stock bottom end 6-speed f-body. I have talked with the other 4 or 5 guys that are on that list in the 9's that says 346 or 347ci and all have said they had full built motors when they ran those times. none ever went fater than speedy when they had a stock bottom end. now i'm sure theres all kinds of faster cars out there that dont even post on ls1tech. so we will never know. I should be able to bust out a 9 sec pass in spring with no problem. my 10.20 pass had some nitrous issues and needed suspension tweaking.
Old 12-20-2011, 07:36 PM
Sprayed 99's Avatar
I bought a bellhousing from smokeum99ta couple years back. when i spoke to him on the phone he claimed his 9.80 on n20 was on a stock bottom end. i asked for details about his engine but he straight up told me he wasn't gonna tell anyone about his set up. so far as i know thats the fastest, if his car was a legit stock bottom end.
THE 6SPEED LIST NEEDS UPDATING!!!!! WTF??!!
Quick Reply: Fastest stock bottom end 6-speed?
