Too much duration?
Too much duration?
I've got an 04 sierra with a 5.3 with 241 heads shaved .050. Right now I'm running a 224/224 cam but I want to change to give myself more towing power. Everybody has told me to get a 212/218 cam to tow. So I been reading and I decided to spec my own cam. I came up with 212XE/220XER, .558/.581, 112 LSA, 108 ICL. I went with the XER on the exhaust for the agressiveness because I only have shorty headers. My question is, do you guys think that the exhaust duration is too much? Should I stick with 218 or will I be good with 220? Thanks in advance.
Thanks for the replies. I thought about the XFI lobe but unless I can get that lobe in less than .590 lift I really can't use it. My valve clearance will only clear .590, as far as I know.
I have this "Torque Monster" (per article) cam available if you are interested...Crane 1449551. It has zero miles/time on it. (Cam is sold)
http://www.hotrod.com/techarticles/e...camshafts.html
Well my friend and I are gonna try to go together and get a couple cams, maybe at a discount we hope. But, what would be the advantage to the XFI lobe? Would a 206* .585 XFI work, or would that be getting too small?
Well that's what I'm lookin for but I'm worried about valve clearance. My heads are stock 241's shaved .050. I have dish pistons. Would .595 lift clear you think?
So then, what I need to calculate is at what point the intake would be at maximum lift. I know that if it isn't at greater than .590 I'm good
