Maybe clutch?
Old 10-31-2011, 09:39 PM
Jr.Samples's Avatar
Default Maybe clutch?
Question.
When I am in higher gear 3 4 5 or 6 cruising about 2,000RPM or most any low RPM when I give it a little gas to speed up some the car jerks over and over pretty hard until I get up to around 3K or so. This is so anoying and not much driver friendly.
I have had the trans recently rebuilt but I know it did it before that anyway. Is this a clutch issue or perhaps a misfire under load? The clutch is not new but seems to not slip at full throttle. I am not throwing any codes except the occasional P01416.
Not sure where to look. I suppose I could live with this unt I put a clutch in it but am not 100% it is the clutch.
Thank you in advance!
Old 11-01-2011, 10:11 AM
Jr.Samples's Avatar
From reading other post this may indeed be a clutch issue. I can smell it after a few hard launches too.
Old 11-01-2011, 11:46 AM
Nowhereman's Avatar
How many miles on it?
I noticed mine gettin weak after about 110,000 miles.
I'm replacing mine with a Yella Terra ultra light steel flywheel and a twin disk setup from McLeod..
Old 11-01-2011, 12:55 PM
TDP
TDP's Avatar
One way you can test it would be to stick it in 5th gear while going 20-25mph. Floor it and if it slips and the RPMs shoot up, then the clutch is gone.
I've got a deal on the Stage2 basic kit for $369 shipped, or the complete kit (with flywheel & slave) for 689 shipped.
Old 11-03-2011, 03:57 AM
SSLSXLQ9L92's Avatar
How much power will that stage 2 hold ?
Old 11-03-2011, 03:33 PM
Jr.Samples's Avatar
It doesn't slip it just bucks and jerks real bad before climbing up in the RPMs
Old 11-05-2011, 08:16 PM
Dave-1970's Avatar
I had this same exact problem, years ago when I bought a 94 trans am with a T56 and 105k on the clock. I too thought the clutch was slipping when I hit the gas at certain rpm's, though it turned out to be a trouble code that was easily fixed...Problem went away after code was cleared...
Old 11-05-2011, 08:30 PM
WS6SP33D's Avatar
I know this is probably not your case but i get ppl in the shop all the time when at a high gear low rpm's car jerks and misses that feel like a jerk. 9 out of the 10 i fix come back to a cracked plug or bad wire. I figured you have already covered this just my .02
Old 11-06-2011, 08:36 AM
Jr.Samples's Avatar
I think you may be right. That is my next place to look. Once in a while I will get the random misfire code.
Thanks.
Quick Reply: Maybe clutch?
