anyone using gapless rings for FI?
Old 11-04-2011, 03:03 PM
lmt0705's Avatar
Default anyone using gapless rings for FI?
just wondering if there would be an advantage to using gapless top ring for my rebuild? Is anyone using them, good or bad expieriences?
Old 11-04-2011, 03:38 PM
stevieturbo's Avatar
Ive used them a couple of times. They work just fine, and will be using them again
Old 11-04-2011, 04:14 PM
forgedlt4's Avatar
I am currently using them. no issues so far with them.
Old 11-04-2011, 04:15 PM
lmt0705's Avatar
anything bad about them? why dont more people use them for FI? we should have better leakdown and make more power with them right?
Old 11-04-2011, 04:47 PM
mr_biscuitz's Avatar
I used them on my last rebuild but only got about 300 miles out of the rebuild ;( not the rings fault. Picked up some power def compared to my other rings. I think the only downfall is they will wear faster
Old 11-04-2011, 05:16 PM
People probably dont use them as often as they are more expensive. And to say they will wear faster makes no sense at all.
Old 11-04-2011, 08:24 PM
Thats what total seal told me, they said they dont rec. them for cars that see alot of street time due to the fact of more miles and they will score your cylinder walls over time.
Cam72aro's Avatar
I agree, why would they wear faster? They don't hold more tension than a standard ring.
Old 11-05-2011, 05:19 AM
Ive used them and never had issue. Dont forget, the "gapless" aspect only applies to one ring in nearly all cases.
In mine it was the top ring. It's a stainless 2 piece affair to create the gapless effect.
But the 2nd and oil rings are just conventional
As long as they are used correctly, bore finish is good, then I see little reason why they would wear faster, and certainly no reason they would score the bores.
Old 11-05-2011, 07:42 AM
Simply what they said, pretty sure it even says it in there catalog.
I also use the top gapless ring set.
Old 11-05-2011, 01:19 PM
lmt0705's Avatar
What benifits do you think your seeing from them?
Old 11-05-2011, 01:29 PM
Probably very little.
But I have had other plated top rings where the plating has come off the surface. This cannot happen with the stainless ring.
Old 11-05-2011, 01:32 PM
lmt0705's Avatar
As far as the gapless top ring goes what are the benifits
Old 11-05-2011, 01:37 PM
What benefit could a full circle seal offer against a seal with a gap ?
I think the benefit is obvious, even if in reality it it is only very small.
Normal rings dont have a gap because they want a gap there, it's simply required by design.
Obviously gapless rings do still have a gap, but by design the 2 rings overlap so where the normal gap would be, there is still a solid piece of ring passing over it.
If there really is a measurable difference, it would be incredibly small. Most likely less blowby, and less crankcase pressure.
Power.....doubtful it will really make any difference
Old 11-05-2011, 02:04 PM
nubs4ck's Avatar
I am using total seal rings on my setup. They are expensive as people said, around $420 a set for me. My engine builder definitely recommended using them.
Old 11-05-2011, 06:26 PM
I def seen less blow by and also picked up more power. Dont have a back to back dyno pull diff.
Old 11-05-2011, 06:44 PM
lmt0705's Avatar
Sounds like a good idea, would I want a nitrided iron ring,stainless or chrome
Old 11-05-2011, 08:15 PM
AFAIK, gapless top ring comes only in stainless.
Old 11-05-2011, 08:17 PM
Old School Heavy
speedtigger's Avatar
I used Childs and Albert Z-Gap rings on my Grand National. Excellent product.
Quick Reply: anyone using gapless rings for FI?
