Pontiac Firebird 1967-2002 - New owner with ?'s
Vortec HD
11-06-2011, 07:34 PM
Just picked up a 00 Firehawk. Trying to figure out what a sound from the rear is when I hit certian bumps only on passenger side. Sounds like a hollow sound. Checked the shocks to make sure there was no movement. Where is my next area to investigate? Also how do I know what suppension package I have? I have orange shocks.
z-maro
11-06-2011, 08:24 PM
Congrats on the Hawk. I don't know what the sound is, however if the sticker on your door jam is not legible, you can call SLP to get the info on if it has the Bilstein suspension. I believe the Bilstein's are yellow though.
Vortec HD
11-07-2011, 10:20 AM
Called slp. Looks like it is build number 465. they said I have stock trams am suspension. I to thought Bilestins were yellow, mine are orange
babbage1109
11-07-2011, 10:24 AM
Is your car lowered at all? I have a noise web I go over bumps and have come to the conclusion it's my panhard bar hitting the upper one when the suspension is uneven
LSX-WS6
You say sound is coming from pass side. Can you tell if it is coming from front, rear or right unger pass seat? Also congrats on purchase
Vortec HD
11-07-2011, 10:42 AM
Sound is defiantly coming from the rear passenger side. Only over certain bumps. Just trying to see where I should be looking. Don't want to replace what is not the issue. Like I said sound like a hollow sound when it happens.
PontiacFan
11-07-2011, 10:51 AM
Check to see if there is a legible 'second sticker items listing' decal on the passenger side door jamb.
slimmer
11-08-2011, 07:52 AM
Spare tire tight in trunk.
ghardester
11-08-2011, 01:37 PM
The orange shocks you have are the stock DeCarbon shocks.
y2k_ta
11-08-2011, 04:36 PM
The sound your hearing my be the spare donut tire moving around. It's back there on the passenger-side behind the plastic interior panel.
Vortec HD
11-09-2011, 11:47 AM
Would a blown shock make the noise? Think I will be replacing the with new Bilestins.
So took the spare and jack out. Still making the same noise. Any other thoughts? Looked at the pan hard bar looks like itis not tubing and exhaust looks good for clearance as week. Stuck on this.
Maybe the bump stop is missing on your frame and the suspension's hitting the car?
82cetuner
11-10-2011, 08:39 AM
no your not ganna bottom out on some little bumps just cause the bumpstop is not there.
check all your bushings could be one of them is worn out. also could be one of your spring isolators is shot. still could possibly be the shock too.
I had the same issue on my T/A I never really did any investigating cause I planed a strano/koni setup anyways. i had a ws-6 with decarbons as well with 110k
dlft600
11-11-2011, 02:28 PM
Had a similar noise coming from ther rear passenger side in my WS6. It turned out the the lug wrench near the spare tire jack was loose. It only rattled when hitting certain bumps.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
