6.0 Turbo Cam
Old 11-07-2011, 02:45 AM
bluecar's Avatar
Default 6.0 Turbo Cam
Stock LQ4 ported 317 heads twin 62mm need some help with cam selections have 2 cams FTI 230/228 612 600 115LS and a GT2-3 207/220 117.5 581 589. Thanks
Old 11-07-2011, 07:38 AM
bluecar's Avatar
Any advice on the cam selection 2000 camaro street car looking for 700+whp turbo 350 with 9' nitrous converter something just to play around with in the south street action
Old 11-07-2011, 08:30 AM
oange ss's Avatar
FTI cam
Old 11-07-2011, 12:54 PM
Fbodyjunkie06's Avatar
fti cam
Old 11-07-2011, 12:58 PM
bluecar's Avatar
Reed at Work Turbo is setting up the exhaust housing what AR for good spooling footbraking, 60 or 80lbs injector
Old 11-07-2011, 09:24 PM
Your gonna need more than 80#'s of injector. More like 96 or 120.
Old 11-07-2011, 10:16 PM
mike13's Avatar
For 700whp?
Old 11-07-2011, 11:47 PM
skinnies's Avatar
80's will be fine, I've made over 850rwhp on them with e85, I run the gt2-3 cam in my setup and really like it.
Old 11-08-2011, 12:30 AM
bluecar's Avatar
I have the GT2-3 cam still would like the muscle car sound, but don't want the lazy spooling.
powerband on the FTI 2400-6600 thinking i have enough converter for the cam.
Old 11-08-2011, 07:10 AM
dudeman's Avatar
i ran the va speed vtc3 cam. it made 753whp@16psi with stock 317 heads on a 6.0 using an 80mm turbo.
Old 11-08-2011, 08:24 AM
bluecar's Avatar
Is the reverse split camshaft in a twin turbo motor needed. Cams that does not looks like turbo cam are used and makinge power, example the GT2-3 just doesn't looks right on paper but popular with the turbo guys.
Old 11-08-2011, 08:27 PM
baker7902's Avatar
what was the compression ratio of you motor? intake? tanns?
Old 11-08-2011, 09:02 PM
bluecar's Avatar
Stock LQ4 rod bolts and head studs and a LS1 intake turbo 350 trans. Thanks
Old 11-09-2011, 06:36 AM
bluecar's Avatar
Could you use 60lbs injectors with meth injection for 700whp+ and not use the 80lbs.
Old 11-09-2011, 07:21 AM
Nitroused383's Avatar
What was the FTI cam specced for? I'd ask Ed curtis, he knows his stuff. The GT2-3 will sound like a stock cam and the FTI cam will have slight lope. The valve events on the FTI cam will spool the turbo's quicker and make more power above 6000 rpm. For twins I think you could run a little more overlap and a positive split duration with a little later exhaust valve closing event. I may be interested in the FTI cam if you don't use it send me a pm.
Old 11-09-2011, 10:18 AM
bluecar's Avatar
The cam is spec for a single turbo 900hp+, power above 6000 rpm is dangerous for the LQ4 just not sure how well it would work with twins.
Old 11-09-2011, 03:59 PM
Orr89rocz's Avatar
twins or single doesnt really matter as far as the cam goes. The overall system needs looked at from heads to manifold to header design. FTI cam will do ok. I'd run that. My friend runs a 230/236 in a LS2 based motor with ported 317's and made 816whp on a mustang dyno on 11 psi with E85 and alot of meth. Stock bottom end + rod bolts.
Old 11-10-2011, 01:53 AM
bluecar's Avatar
Would Twins 62mm give me enough HP to run low 6's 1/8 mile with a factory looking camaro.
Old 11-10-2011, 02:51 AM
baker7902's Avatar
ok so what about the speed inc TU2 turbo cam? i have heard good things about it anyone run this cam?
http://speedinc.com/cont.cfm?cid=C0000150
Old 11-10-2011, 05:21 AM
bluecar's Avatar
OK the TU2 and FTI mention above which one would be better for the twins, now the TU2 is a single pattern and the FTI is reverse split.
Quick Reply: 6.0 Turbo Cam
