General LSX Automobile Discussion - I have a tick.
_Silver_
11-07-2011, 12:15 PM
I have a tick that increases when I rev. Not super loud but noticeable when the windows are down. Any ideas on what it could be?
the_merv
11-07-2011, 12:23 PM
Exhaust leak..or a Lifter.
V68Sweep
11-07-2011, 06:23 PM
Knocking?
n20z28
11-07-2011, 06:43 PM
Or rocker arm... needle bearing come out.of.them
arioch
11-08-2011, 01:50 PM
its definitely not knocking, and its also not down on power. RPM dependent and pretty loud tick.
That's the GF btw...
thegodfather899
11-10-2011, 09:19 AM
my car does the same. probably a lifter...im not gonna worry until i need to.
sscamaroburn02
11-10-2011, 12:32 PM
most likely a lifter. I have lifter issues that come and go. Car still runs strong though.
SSLSXLQ9L92
11-11-2011, 12:45 PM
Mine was doing the same thing. Ticking seemed to come from up top, and would increase with RPM. No power loss, no miss, no error codes. Turned out to be a lifter. Car is now receiving a LQ9/L92. :D
.cammedZ
11-11-2011, 03:42 PM
Has the engine ever been over-revved? Stock pushrods bend easily and then make noise.
MikeWS6
11-11-2011, 05:06 PM
Had the same problem last week. It ended up being an exhaust leak due to a bad header gasket.
arioch
11-11-2011, 07:39 PM
the car has never been overrevved and has about 70K on it now, it was a 99 and she bought it with around 55K on it last year so it sat around for a while.....
New plugs, wires, filter, all around tune up, it really sounds like an exhaust leak to me but maybe when i see her next well get a video for you guys to hear
01 CamaroSS SLP
11-11-2011, 10:34 PM
Could be Valve train, exhaust leak, lifter, a plug that isnt in all the way. There's a ton of different things it could be. Just have to start looking and start eliminating. I have a tick and i took the easy way out after i couldn't pin point what it was... brought it to a lsx builder and it turns out to be your normal noisy ls1. Mine had 16,000 on it too.
+badss+
11-12-2011, 05:47 AM
yeah mine has piston slap sounds like a diesel lol, but now thats its colder in the am when i start it its even worse. as i start driving it goes away once warmed up no change in power.
its very annoying.
arioch
11-12-2011, 01:42 PM
How does one check for the lifter/valvetrain issues? i remember hearing about a screwdriver up to the head and listening trick, or something like that.
Dont really have the tools or space to do any head removal type work, im in an apartment
01 CamaroSS SLP
11-14-2011, 06:38 PM
You would have to pull the valve cover off to take a look inside. I wouldn't do that until you check your exhaust for leaks, maybe check your plugs to see if ones loose. If you cant find anything i would take a video and head over to the internal section where someone more knowledgeable will be able to help you.
blk/slvr02ss
11-14-2011, 07:32 PM
I Would not worry about it happens to almost all of the LS Motors my 2010 Camaro SS & my 08 Vette both make noise.
