Trans am 5.3 turbo build
my set up.....
1996 trans am
lm7 5.3 stock bottom end
ARP Rod bolts
Ls6 cam
front truck mount
s480 turbo 1.10 ar
Meth injection
victor jr intake manifold
CA 91 pump gas
4l80e
3.27 gears
3600 stall
2 step
Should i run 317 heads or would my comp. just be to low.. or just stick with th 5.3 heads.... i want to run like 12-15psi 600rwhp plus building it for the track 1/4..
thanks for the help
1996 trans am
ARP Rod bolts
Ls6 cam
front truck mount
s480 turbo 1.10 ar
Meth injection
CA 91 pump gas
4l80e
3.27 gears
3600 stall
2 step
thanks for the help
I'm sure others will chime in but from what I have been told...if you are only planning that much boost and conservative hp, the stock heads will be more than enough. The cam looks a little on the big side. My cam is considered pretty aggressive and it is a 224/230 .581/.588 114 Yours is even bigger than that. Probably going to need some different valve springs also. I was told the Patriot Gold Duals are nice. That was what I got.
Hopefully, some others will chime in. I am also in the process of doing my first build so take my information with a grain of salt.
[QUOTE=pwrtrip75;15640298]Leave stock heads, works way better and you shouldnt have an issue. I'd skip all the ARP stuff too... that turbo wont make enough power ghs around
