cam swap coming soon i need advice for my trex cam swap
Old 11-22-2011, 01:16 AM
Brandon331's Avatar
Default cam swap coming soon i need advice for my trex cam swap
I am going with 243 heads ported and polished with a trex cam will i need too fly cut my pistons ?
Old 11-22-2011, 05:01 AM
Captain Double Post
BOBS99SS's Avatar
I m going to tell you to rethink your cam choice. Unless you know what your getting into, big cams are not a budget way of going fast, you will need every Max effort part, and a good gear to get it moving. Again if you know what your getting into then by all means go for it, just when ever I see a thread asking about the t Rex or anyother big cam I always say stay away.
Old 11-22-2011, 07:33 AM
RARON455's Avatar
He's right, you need the parts to work together.
Old 11-22-2011, 07:54 AM
godlyxdan's Avatar
What other mods have you done? That cam with those heads by themselves wont help unless you have mods to support them
Old 11-22-2011, 08:10 AM
Captain Double Post
BOBS99SS's Avatar
op listen im going to just say your kind of new to ls cars, if your not my bad, but there are so many people that just think the biggest cam will make there car the fastest and make the most hp, that couldnt be more wrong, when i first put in my ms4 cam the car was a dog, i didnt know what i was doing at the time i just got caught up in all the big cam bs.i will tell you if you dont have the mods to run this cam your car will be a dog as well, i will say if you set a big cam up right they can fly, and if your looking for a big cam sound you can get that in a much smaller pro file .if i could do it all over again i wish i would have went smaller, but im getting this car to run to show what this cam can do when it is set up right. the best move you can make is call eps , and get your heads set for a cam they set up for you.
Old 11-22-2011, 08:18 AM
Captain Double Post
BOBS99SS's Avatar
just trust someone that has been there,not to many people will tell others there f ups lol, thats just how i learn lol,you really have to add what the car is going to be used for, street use, track only ,dd, etc
Old 11-22-2011, 08:38 AM
Rare96LT1Formula's Avatar
To answer the OP's question, you may need to flycut. You'll need to be ready to measure PTV to be sure. Don't risk damaging your motor and just do it to be sure.
Old 11-22-2011, 08:40 AM
Brandon331's Avatar
Well it's going too be a stock block street car/drag car not a dd I kinda know what I'm getting into its why I'm asking if i need too bc I know its kinda a hit or miss with this cam some people can get away with out it and some people have too I'm planning on having the heads ported and polished running a 90/92 when I can find one along with some 42 lbs injectors… and yes I'm fairly new too ls1's I've only been around them for a year it's why I ask questions if u don't know something there is always some one that does ya know and I was planning on running a 4 10 till I broke the ring and pinion for the ten thosandth time and up it too a 4 30 gear for when I switch too a 12 bolt or a 9" can't make up my mind on which one I want lol
Old 11-22-2011, 08:45 AM
My buddies brother runs a trex and 243's, and he says his brother DID need to flycut.
Old 11-22-2011, 08:46 AM
Captain Double Post
BOBS99SS's Avatar
you should fly cut , not just for clearance
Old 11-22-2011, 09:01 AM
Brandon331's Avatar
Thanks bud appreciate the advice
Old 11-22-2011, 09:09 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
I agree with Rare96LT1Formula, PTV clearance should be checked with any decent sized camshaft installation. A fraction of your time spent checking could save you alot of money.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 11-22-2011, 09:20 AM
BuckaroooZ28's Avatar
I did Not flycut....using stock ls6 heads
Old 11-22-2011, 09:37 AM
408sharkmaro's Avatar
Im running the texas speed ms4 and im upgrading to the heads the recommend or I just might send in my ls6 heads to get ported and polished by them.
Old 11-22-2011, 05:39 PM
Captain Double Post
BOBS99SS's Avatar
408 what does your post have to do with this thread LOL.if its a drag car by all means go for it, if you have a m6 go 9 inch for sure.also I hate to say it but in a drag car and m6 the money your going to put in that ten bolt isn't going to last you long at all.if your an auto you can get away with it for awhile but its a ticking bomb.also a good idea would be katech rod bolts, your going to be spinning it very high.as far as the fast intake I would shoot for the 102, unless you can find one with a decent port job or port it yourself.IMO building a drag car requires a lot of the time at the track. If you listen to everything you hear on the internet you will just waste money.good luck though man,
