She blew!!!!
She blew!!!!
So I bought a 98 z28 LS1/T56 she ran very good but had a slight tick. drove it bout an hour and then she blew. rod DID NOT seperate from crank, but the rod snapped in half and took out the block on the way out. now my question. how did this happen? i had two bent pushrods on that cylinder, could bad lifters have cause this? cause i cannot think of a solution to this for the life of me. looks like a foreign object got in the block and jamed the rod and snapped it but that is not what happened. so i do no no any info would be great. should i replace with the 6.0? or a built 5.7?
2500 rpm for an hour, normal highway driving, if that block has my name on it maybe you could send me a pm with your price
valves are still on the keepers and they are bent to ****
How many miles on it? Was the bearing spun too? Its not uncommon to see a Ls1 rod snap like that, they are not a standard rod. They are powdered metal cracked end rods<****** JUNK. Extremely cheap to manufacture.
Do youself favor while you are in there and replace the JUNK standard LS1 starter with the updated truck style that uses two long bolts. So you don't suffer from the cheap azz standard starter housing breaking off then twisting the outter starter bolt boss off the block.
Hell go buy a Ford!
Hell go buy a Ford!
And dont listen to that guy ^^. Research will show you that and what leads to any rod failure. You said u just bought this car? Who knows how it was driven before. The weak point in these engines are the rod bolts. Most rod failures I've seen is running it hard on a cold start up.
Hell go buy a Ford!
Hell go buy a Ford!
Stock ls shortblocks have gone 9's multiple times the rods are def not a big weak point its usually the rod bolts that let go. If cracked rod caps are so inferior then someone should probably go tell chrysler who uses them on their modern hemis, ford who uses them on their mod motors and chevy who uses them in the ls3 that they're crap and should be changed.
OP it sounds like a fluke thing which happens I'd throw a new shortblock in with a decent cam and have at it.
rods don't just snap in half for no reason. You said the big end is still on the
crank but that doesn't mean that the bolts didn't stretch. When this happens
the bearing clearances open up and start wearing the bearing shells out real
fast. Each time the crank turns the piston travels further north until it hits the
valves and or head. Impossibly trying to compress valve heads(after breaking)
or the forces exerted on the rod when crashing the head causes the piston
and rod to part ways either in the beam or at the wristpin. Even at normal
cruising speeds this will obliterate an aluminum block. Very sorry to hear of
your misfortune and best of luck reloading.
Powdered metal rod are like glass, nothing like a forged rod etc. They can break easily depending on the stresses applied. Don't let anyone **** you up otherwise THE ONLY reason they use them is because they are CHEAP to manufacture.
Looking at that train-wreck of a thread on thirdgen.org, I can take a wild guess as to why your engine failed:
Glass in the cylinders??
Working on the car w/ the intake off and the heads unsealed:
Or maybe you installed the crank wrong...what clearance did you measure at the main and rod bearings?:
Used your new ARP head bolts as a lifting chain mount?
I realize you probably didn't end up using the ARP bolts on your engine, but it shows a lack of mechanical ability that makes the engine's failure nearly certainly your own doing.
i had this gut feeling that the motor had glass in it from that and of course took driverside head off and there is glass i do not no how it got there but it was there. so i am gonna tear my motor back apart lol and re due her all over again.
here is my theory. glass landing in the intake port. then when i turned it over with a wrench it fell in
this is a ls1 with the crank that you had sold to me.
i put a chain in the head bolts holes with the arp headbolts holding the chain in and it bent. to me makes arp sound cheap
