408 stroker big cam surging at idle
i just had a 408 stoker put in my zo6 and we did the fast 102 intake with the 92mm tb. this may just be a tuning issue but i cant get it to idle vary well. it wants to surge at idle. what might this be?
I've had tunning issues about idle. I've had several tunners TRY! It pisses me off to drive it sometimes. WOT is like sex but slowing down a PITA. I think its a throttle cracker issue, seems to run too rich. I've heard my 102 TB is too big..etc...I'm considering going SD. I just can't keep throwing money at tunners. I'm going to try a BIG rice tunner. We'll see. Oh I did check EVERYTHING for air leaks and re tq'd the intake.
I would tell you to check for air leaks.
Look at the Desired Airflow, Base Timing / Timing table, Commanded AFRs, etc, etc... It probably needs more idle airflow, at the very least.
cheers
cheers
