My BMR 4L80e crossmember doesn't fit right
Old 12-03-2011, 09:51 PM
evo462's Avatar
Default My BMR 4L80e crossmember doesn't fit right
Kinda miffed about this, because I found two other threads about this exact issue from a few years ago, and apparently it's still a problem.
I have a 1993 4L80e that I am swapping into my 2002 Camaro. I bought the BMR 4L80e crossmember/tq arm relocation setup and can't install it because the cross member rubs on the rear passenger corner of the transmission case/pan area.
Here is another thread on it:
https://ls1tech.com/forums/automatic...ossmember.html
Here is the part that rubs:
In the thread linked above, someone talks about notching theirs with a cutting wheel then re-welding the hole which I don't want to have to do considering it was a $250 piece of hardware. I guess I don't really know what else to do except contact BMR on Monday for advice, but thought I'd see if anyone else ran into this problem because I know a lot of you have swapped 4L80e's into your F-body's.
Old 12-04-2011, 08:32 AM
ShevrolayZ28's Avatar
Bummer. I had to cut, reposition, and reweld the torque arm mount on my 4l80 cross member. (I can't recall for sure who made mine, but I know it wasn't the one shown in your pic.) Any chance it would clear if you could heat it and put a good dent in it there?
It sucks but that's the way it goes with many after market parts...
Old 12-04-2011, 09:42 AM
evo462's Avatar
I dunno, it feels like it's pretty thick metal.
Old 12-04-2011, 10:02 AM
evo462's Avatar
What other options are there? Not that it'll help me at this point, but maybe someone else can avoid this part if it's defective, which it seems to be.
Old 12-04-2011, 10:05 AM
MUSTANGBRKR02's Avatar
MWC makes a nice one.
Old 12-04-2011, 10:20 AM
El_Diablo's Avatar
I have a moroso deep pan that it wasn't clearing at the lip. Looks like about the same problem here.
Old 12-04-2011, 10:31 AM
evo462's Avatar
Mine is just the "regular" factory pan. What did you end up doing to get it working?
Old 12-04-2011, 01:14 PM
Cam72aro's Avatar
Can you put a small spacer between the trans mount and cross member? Just be sure to check the angle at the back of the trans.
Old 12-05-2011, 12:29 PM
evo462's Avatar
I dont know that a small spacer would give enough clearance, unfortunately.
Old 12-05-2011, 10:56 PM
El_Diablo's Avatar
I didn't want to jerry rig it so had a chassis shop make another one like I should have done to begin with.
Old 12-05-2011, 11:07 PM
Gingervitis Addict
slow67's Avatar
I used the yank crossmember, no problems here.
Old 12-07-2011, 07:43 PM
evo462's Avatar
Couple days now and *crickets* in response to my email to BMR tech support. Guess I will have to call tomorrow.
Old 12-09-2011, 05:25 PM
Hear anything?
Old 12-09-2011, 07:57 PM
evo462's Avatar
Yeah, I got right through when I called and spoke with someone very friendly and helpful. Guess I should have done that to begin with.
From what I gathered, they are aware that some out of spec ones made it out to the market and are offering replacements to anyone that got one. I don't imagine it was intentional, but hopefully I get my replacement soon because I can't really make further progress on my build until the transmission is secured in place.
Old 03-22-2013, 08:39 PM
ls1freak33's Avatar
Would there be a problem if I made the slots bigger on cross member to where it would slide back far enough from trans, I didn't think of any. Just wonder if anyone would know.
Thanks justin
Old 03-22-2013, 08:44 PM
Blackbird-WS6's Avatar
This is a 2011 thread. So im guessing they still have this problem bc I might be buying that part soon
Old 03-22-2013, 09:25 PM
Burken01's Avatar
mine fits fine doesnt hit the tranny, i just got one in december
Old 03-22-2013, 10:12 PM
ls1freak33's Avatar
I must got a older one then, bought it as a whole setup from a buddy, was going to cut slots in the way I need the cross member to slide on a mill. I will have pics to up date on how it works out, be Mon before I get a chance to do it.
Old 11-18-2015, 07:40 PM
s25hanh's Avatar
Sorry to bump an old thread but I am also have the exact same problem. My transmission pan is rubbing on the crossmember and the trans mount does not line up. It's about a half an inch away. BMR TC0021. Going to call BMR tomorrow, supposed to be on the dyno Saturday ughhhh
Old 11-19-2015, 03:45 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I am glad we could get you all squared away and taken care of.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Quick Reply: My BMR 4L80e crossmember doesn't fit right
